06' TL Transmission issue
My driver side ball joint snapped, I replaced it and the cv axle. Went to test drive my car and the MT popped out of gear, then when I attempted to shift back into 1st it does't engage the tires to move like it isn't in gear although it is. Where should I start? I did see that the ATF oil was leaking out when I got down to see what is going on. Thank you
Welcome to the forums.
The following is posted at the top of the New Member Introductions forum: Welcome! Please introduce yourselves here, but ask for help in the Technical Forums Since this is a topic/technical issue which will require replies and discussion, this thread has been moved to the model specific forum. |
You say MT and then you say ATF
is your car an automatic or manual? |
It's MTF. it's 6 speed mt. Just forgot what it's called.
Make sure the axle was installed properly. That was the only thing that changed last, so i'd re-inspect.
