'06 TL Front Seat Won't Move - Checked Obvious Fixes
A few months ago the driver seat started being touchy and would only move the seat forward/back up/down on occasion. Eventually it stopped working all together, which prevents my wife from driving as she is significantly shorter than I am. After reading several threads I had tried the typical fixes, fuses, motors worn out, switches and haven't had luck. I eliminated the motor or gears stuck as the memory buttons still work and will move the seat from memory position 1 to position 2 and back. As this still worked I thought it was just the switches, however after replacing the switch I have the same issue. Anyone have any other ideas to try? I'm guessing its something electrical, but other than the memory circuit board I'm out ideas. As the MSC unit is $100 I don't want to buy it unless I'm certain, as as the memory buttons are still working I makes me believe this couldn't be the problem.
asahrts
09-04-2015 05:55 PM
