'04 TL--need help
'04 TL--need help
So yesterday I was driving and started hearing this grinding noise from the rear it was very loud and kinda sounded like the noise it make when u have a flat tire like a "thud " noise so I went back home and lift the car up and check the rear wheel and they were hard to spin and sound like something is grinding...I posted a video if it helps ...thanks
http://youtu.be/ujngUSo2ltU
Next if its not that see if the plate behind the disc is rubbing against the disc and causing a noise.
For the most part I believe its your wheel bearing.
I've had my shields rub somehow if everything wasn't tight but that sounds like a bearing to me. I replaced my hubs and bearings on my FX and it wasn't bad at all. If you are some what handy, I think you should be able to do it.
