04 TL headlight question
Old Jul 25, 2010 | 08:43 PM
tn_viper's Avatar
6th Gear
I have an 04 TL that has headlight problem. Sometimes the passenger side will work sometimes not. Also it isn't as bright as the drivers side. I am thinking it is in the ballast in that light.
Any ideas?
Old Jul 25, 2010 | 11:10 PM
YeuEmMaiMai's Avatar
swap the bulbs around and see what happens, if the problem follows the bulb, replace both of them. If the problem stays in the same spot check wiring and ballast
Old Jul 27, 2010 | 04:23 PM
tn_viper's Avatar
6th Gear
Headlight
Already put in new bulb on that side. Didn't change anything.
Old Jul 28, 2010 | 01:58 PM
TLSkier's Avatar
I'm not an expert, but I'm told it's more a question of the ballast failing more so than the lamps. When the lamp fails, there's no illumination, period.
Old Jul 30, 2010 | 09:24 AM
saltysteve's Avatar
swap the head lights and check to see if works or not. sometimes itll work for a little while then quit.
then it could be your ballast or ignitor.
this happened to me. i replaced the bulb and it wasnt the bulb.
then i bought a ballast and its not the ballast - its the ignitor which im replacing now.
the bulb color differnce is probably because someone tried to fix your light before with a bulb replacement and put in whatever lumens bulbs they wanted (the cheapest)
buy a new set of bulbs if the colors are off
BoricuaTL
Apr 8, 2016 01:08 PM
pistacio
Sep 26, 2015 09:45 AM
eastcoastguy
Sep 24, 2015 02:07 PM
datadr
Sep 12, 2015 09:12 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
