'04 TL has sweet smell under hood
i have an 04 TL auto with sport shifting. I was on the interstate, running it hard and when I got home and pulled in the garage, there was a sweet, almost maple syrupy smell coming from the engine bay near the fire wall on the passenger side. Maybe even a plastic melting smell. It was weird. Im new to the TL so Im just learning the motor and whatnot. The car has 38k original miles also. Any advice?
If it's at the firewall, could be a loose/cracked heater hose or a failing heater water valve (not sure what the official name is). The smell is most definitely coolant.
As the coolant will evaporate on the hot parts, sometimes it is difficult to pinpoint unless there is running liquid. If coolant level has dropped, or just to check, throw a pressure tester on the cooling system when cold. It can be done cold or warm, but I prefer cold. Let it sit for quite a while to see if the pressure drops, and if it does, look for the coolant.
The first and easiest place to check is the little hose between the radiator and overflow tank. Mine leaked since new and it was just enough that I couldn't find it until there was a small buildup of dry coolant on top of the radiator. A small black ziptie fixes it. I've seen several TLs leak in this area. It will not show up on a pressure test.
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
DerrickW
11-15-2015 05:52 PM
