04 TL Axle
Depends on how good you are
If I have a lift to do it on, I could do it in 20 minutes. On the ground it'll take a little more time. Remove the axle nut, seperate ball joint, remove damper fork bolt from lower arm, pull axle out of hub, and pull axle out of trans.
