04 TL- any tricks to replacing front wheel studs??
Between the shop that installed my bent rims and the shop that did the alignment, someone stripped two of my left front wheel studs. No one will own up to doing it so I am stuck with the problem.
I've purchased the replacements. Question is- do I need to remove the knuckle to replace the studs or can I just hammer them out and pop new ones in?
Too many $$ toys
how bad are they stripped? why not just get a die and rethread them? check irwin for the size you need.
They are definetly stripped beyond a thread repair.
You don't think I will be able to take a hammer and pound them in gently? I don't have access to a press.
Too many $$ toys
i did that method once and swore i would never do it again. it will not be gentle. use plenty of never-sieze to lube them at the splines, a big steel drift and a BFH (preferrably small sledge). i wore my shooting muffs, because it was so loud and annoying to keep hammering away. find someone with a press and pay them a few bucks. i'd do it if you lived close. it takes just a couple of minutes with a press.
HAS A GHOST IN
I got the same problem to. I was going to take off the front right to clean the inside of the rim and BAMM!! WTF, one lug nut is stripped. Although I didn't fully try to get it off as off yet. I thought I would take to back to Discount Tire and let them balance the tires again here soon and see. They are the only ones that have touched them. I wonder what the will say or will they just try and put it on and not say anything.
im goin through this same problem right now...i cudnt get off 2 of the lug nuts because the stud got pushed back and kept spinning so i had to drill out the lug nut and part of the stud to get my wheel off..i thought taking them off was hard but getting them back on was another task
bought the replacements from auto zone began installing them today...got em done somewhat but they are not seated fully...i used a c clamp and a socket to try to pull the stud thru but thats not even the best method..like another member mentioned a press is the way to go...i might take off the hub and have a shop just press the bolts fully in for me....but trying to hammer it in i think u might be there for days
i also cut the dust cover in the middle to get the stud through otherwise it wont line up properly and will damage the threads
Well.. I took the TL to a friends shop this morning and he replaced two studs for me. All he ended up doing was separating the knuckle from the lower control arm to give him enough room to sneak in a small tool that pressed in the stud with the use of an air gun. Took him about 30 minutes. Cost= free. Lucky me.
He was also able to diagnose the cracking noise coming from my front left- I have an axle going bad. Looks like I have another project to work on.
asahrts
09-04-2015 05:55 PM
mtl_ilx
09-03-2015 09:48 AM
