'04 TL-2000 miles after Timing Belt Change-strange belt rubbing/chirping sound
Registered Big Dog
I DIY'd the 105k service approximately 2000 miles ago with a friend and his dad (the dad is a licensed tech that works @ lexus) We did it according to the instructions including changing the tensioner, water pump, idler pulley, etc. All parts were honda/acura oem. There was no problems with the install.
About 50 miles after the change i started to get the wobbling noise that is of great debate here on the forum, where some say it is a normal sound and others say it may be a bad tb tensioner and they reference a TSB. Based on the debate and the fact that it was minor and there were no issues i did not do anything, i was just keeping a careful eye on it. The sound kinda sounds purring/whirring.
but now i have this sound in addition to the whirring/purring (see below link vids):
http://vidmg.photobucket.com/albums/...186B1F30AE.mp4
http://vidmg.photobucket.com/albums/...7FC364EF58.mp4
So she is parked and i'm going under the hood tomorrow. I'll update, but in the meantime any of you experience this?? or have any idea?
Do you recall replacing/reusing the auto adjuster collar (#9) when replacing the timing belt adjuster pulley (#6)?
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
6th Gear
Try this
I think the noise from your video may me this:
https://acurazine.com/forums/problem...ne-fix-754586/
I did it a few years ago and it fixed my noise. Good luck!
Registered Big Dog
Looks like the tensioner had come loose and a bolt behind the crank in the platic cap had come loose and was nicking the crank pulley
Registered Big Dog
I did not change that; used the original collar (#9)
If i have a problem again i will definitely replace that!
mada51589
05-03-2022 08:54 PM
Phambam12
09-05-2015 04:10 PM
asahrts
09-04-2015 05:55 PM
