'04 Acura TL Malfunctioning Lights?
When I turn on my interior lights the ones in the center console (with the navigation/climate control) would sometimes light but then sometimes they wouldn't. I changed the bulbs and it still does the same thing. Others will light then dim.. then after a while they will get bright again and later on dim (They're LED's). Also, my drive side marker light was previously out but I replaced it and it worked for about a month then it stopped. Then out of the blue it would work again for about a day or two then stop. I replaced both driver and passenger and only the driver side seems to be doing that. In addition, my headlights would turn on but then one would go out or change color, when I turn them off and turn them back on again the light that was working would stop and the light that wasn't working before would work. If I turn it on one more time both of them would not work. Off and on one one last time, both of them would work then it cycles again. I recently changed the ballast but the problem persists. Does anyone have any ideas as to what the problem(s) is/are? Suggestions, comments, or questions about my issues? Please and thank you.
Sounds like either a bad MICU or something
BoricuaTL
04-08-2016 01:08 PM
