Tony's baby with her new skirt (A-SPEC)
Dr. Feelgood
Hi Guys,
I just wanted to share some photos of the A-SPEC body kit I've recently installed.
Sorry, I kind have went nuts on the pics
![](http://img202.imageshack.us/img202/6686/grill0233uc.jpg)
![](http://img202.imageshack.us/img202/4281/grill0252vm.jpg)
![](http://img202.imageshack.us/img202/2041/grill0267br.jpg)
![](http://img202.imageshack.us/img202/6378/grill0278ha.jpg)
![](http://img204.imageshack.us/img204/1946/grill0293oa.jpg)
![](http://img204.imageshack.us/img204/460/grill0309es.jpg)
![](http://img16.imageshack.us/img16/6319/grill0313bt.jpg)
![](http://img16.imageshack.us/img16/5686/grill0327zs.jpg)
![](http://img16.imageshack.us/img16/1814/grill0348au.jpg)
![](http://img16.imageshack.us/img16/9983/grill0359fq.jpg)
![](http://img16.imageshack.us/img16/8499/grill0364ej.jpg)
Dr. Feelgood
Originally Posted by Nandito28
Was it hard to install this kit? how long did it take to install it?
Also, I only had the factory jack and that takes a while to raise the car.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Dr. Feelgood
Originally Posted by ImaGRaNTes
looks good! where you get the headlights done at?
Originally Posted by 05TLTony
Worcester county
Hey TonyTL...I wondered if you can help me do the grill on my 06 RL? I live in worcester county too.
Can you post a picture of yourself? I want to see what you look like.....
Dr. Feelgood
Hey tony Can you post the link to the forum you used...I cant seem to find it...Thanks!
https://acurazine.com/forums/audio-video-electronics-navigation-22/remote-start-111317/
These are the instructions posted by Ayethetiense
before you continue to read, you understand that i will not be held liable if anything goes wrong... these are just guidelines if you are interested in attempting this project.
purchase silicone at a hardware store.
pre heated the oven at 200
put it on a wet towel.... make sure the towel isnt too wet or else its gona fog up the inside of the headlight...
let it sit for about 20 min....
get it out with mittens so you dont burn your fingers...
then use your hands and seperate the headlights from the center part of the car to the sides.... be careful of the black silicone so that it does not get on any part of the headlight as you are opening the assembly. its a bitch to clean off. it will be messy
the silicone or whatever the black sticky stuff is is very important to keep. it will stretch as your are pulling it. get a flat head screw driver and gently stuff it back into the groove of the headlights. you will be using this later and it is better then regular silicone.
CAREFULLY take the amber piece out. it is connected to the chrome strip inside the headlight....
while pulling slowly on the amber piece, give counterforce to the backing of the chrome piece so that it does not snap. start from the sides of the headlight toward the center part. (opposite of how you opened up the headlights)
then relax for a bit and let your burnt/tired fingers rest.
squeeze a generous amount of silicone on the groove of where both pieces of the headlight would come together, better more then less. this part will not be visible once it is put back into the vehicle, so it would be ok having excess silicone.
there is a pointed section on the sides of the headlight. angle it so that you get that section in first and then push the rest of the assembly back together. bake it for 10 min and push the sections together trying to make the tabs realign. bake it for another 10 min and do it again. each time it will become more flush.....
then do the other headlight....
good luck!
o, this project is not for the faint of heart... not too complicated but you gotta attack it. if you are scared of breaking someting, get som1 else to do it. the headlight pieces are very sturdy though...
o by the way, i also installed the comptech rear bar and its awesome.... i used the write up that some1 else did as instructions.... worked great except for gettin the bar out... the angle to get it out wasnt clearly stated. i also had a problem getting all the bolts back on. just used a little muscle and did it in different orders tightening each bolts bit by bit to get the angle on all of them... took me awhile but i got it done and this thing is awesome...
i heard a lot of people giving it praise, but o man its even better then i thought.
Dr. Feelgood
Originally Posted by sqzbox
Wow!! Sharp look!
I really like your grille work. Was this aftermarket, or did you build them yourself???
I did them myself. Here is a DIYhttps://acurazine.com/forums/showthr...ht=lower+grill
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
4drviper
09-23-2015 07:42 PM
