Slow restoration thread
Old 01-09-2019, 10:17 AM
  #41
BreezyTL's Avatar
Idk, I'd do $10/hole or $20/Caliper. Plus shipping. I have the timeserts on hand and can get them done and sent back within a week upon receiving them.
Old 01-09-2019, 10:22 AM
  #42
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
All serious tho, if it strip I will PM you, chance are they probably stripped.
Old 01-09-2019, 10:42 AM
  #43
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
hella coils, hella cheap
Old 01-09-2019, 11:39 AM
  #44
truonghthe's Avatar
best part about that I still have the caliper rebuilt kit from Centric.
Old 01-11-2019, 08:37 AM
  #45
shit that is awesome.
Old 01-11-2019, 09:34 AM
  #46
90foxnotch's Avatar
Im about to paint my calipers soon so If I mess them up I'll be messaging you, and youre so cheap $10 a hole.....I cant even find that deal in downtown Toledo!!!
Old 01-11-2019, 11:20 AM
  #47
BreezyTL's Avatar
It's that Azine Hook-up Bruh!
The following 2 users liked this post by BreezyTL:
90foxnotch (01-11-2019), truonghthe (01-11-2019)
Old 01-11-2019, 09:15 PM
  #48
truonghthe's Avatar
Ok today the "big box" show up and it compiling of all parts and fluids about $500 later, all of these parts actually will go on the SSM TL only as I have more stock in the closet for the rest of the TL(s).
I will keep update the thread as progress moving forward, my objective is to restore the mechanical imperfection on this car and enjoy it for a while. The goal is to keep the car stock.
oh joys....
Old 01-16-2019, 08:41 PM
  #49
truonghthe's Avatar
So the old gal end up at the dealer for LCA bushing replacement, oh well meanwhile there couple minor get done as well.
Meanwhile something special is right next door
Old 01-16-2019, 08:51 PM
  #50
mhtut83's Avatar
That's a NICE TL!
Old 01-16-2019, 08:57 PM
  #51
truonghthe's Avatar
Originally Posted by mhtut83
That's a NICE TL!
I got used to the Acura line up and yet under the front its nothing but tubing, kinda like race car construction.
Old 01-16-2019, 10:02 PM
  #52
Null and proud of it
Midnight Mystery's Avatar
Hanging out in the garage, Eh?
Old 01-18-2019, 07:20 PM
  #53
truonghthe's Avatar
Here is a little update from TLC that much needed for the car. I got deal install a set of LCA bushing along with alignment for a hook up price and since then the car handle much better than before.
Front and rear valve cover got a fresh set of seal, 6 spark plug tube seal, recharge A/C system along with valve adjustment, new NGK spark plugs IR from Rockauto. Yah no more leaks from front and back valve cover, if you look closely you will see some of the engine oil still remain on #5 coil. Don't you worry I already clean the oil off the coil pack.
Please remember to flush your clutch line!!! its has the same life time as your brake fluid. I don't think the line ever been flushed since the car was new.
Every of my TL 1st upgrade. Before pic
After much needed modernization
Here is my list for things to do next.
1. Fix the Navi issue, I already order another DVD drive lol.
2. Replace the Honda MT fluid with AC Delco FM fluid.
4. Fresh rotors and pads on all four wheels.
5. Remove the cheap aftermarket sway bar link and put a new set of front/rear sway bar bushing.
6. Flush the power steering fluid and rebuilt the power steering pump.
7. Fix the TL famous "wander mirror" syndrome since right side actuator is discontinued... FML
8. Clean the engine bay and put the plastic cover back on.
That all I can think for NOW lol, as far as driving wise the 6 spd is fun especially shifting from 3rd to 4th and down shift from 4th to 3rd with rev match put a smile on my face every time.
Old 01-19-2019, 03:55 PM
  #54
Pair of TLs's Avatar
Arrow That's the way to do it!
Great job, buddy!
Old 01-22-2019, 06:38 AM
  #55
Awesome, man...
Old 01-25-2019, 09:26 AM
  #56
GhostTL09's Avatar
Love how it's coming along. I think I'm getting the itch for a new restoration as the MRP has no issues after I replaced the Evap Solenoid for the gas cap message. I do have to flush the brake fluid because it was so low I had to add some due to VSA/Brake! light coming on.
I'm thinking of trying to pick up another RRP again and a KBP that needs some TLC.
Keep up the work my friend
Old 01-25-2019, 11:40 AM
  #57
truonghthe's Avatar
Originally Posted by Pair of TLs
Great job, buddy!
Awesome, man...
all of you guys are bad influence and inspiration in a good way lol.
Old 01-25-2019, 03:43 PM
  #58
mhtut83's Avatar
I will be the sourpuss and say, Stop spending money on more cars you don't need! You've got more than enough.
Old 01-25-2019, 04:20 PM
  #59
BreezyTL's Avatar
Just one more, KBP!
Old 01-25-2019, 07:39 PM
  #60
truonghthe's Avatar
Just one more, KBP!
Well I could that had that KBP lol
small update...
Finally I got the out dated navi working again, I feel so weird with the 04-06 Navi since the graphic resolution is slightly less than the 07-08. The proccess speed also slower than my 07-08 TL, some how I end up with all TL has navi. Took the car today for work so I can test out the navi function and in traffic I have to say its not that bad.
No need to worry about the dash being expose to the sun, this is my daily spot park at work.
Its feel so nice to have the clock with correct time back along with all the original function back.
I just had to test out the Navi and compare it with the 07-08.
Well the final verdict is everything working greats except for the outdated 2007 DVD. BTW more update is coming on the way.
Old 01-25-2019, 07:49 PM
  #61
Was the 05 to 07 navi a hard swap, or judt PNP?
TL? "A Compact Car"?
Old 01-25-2019, 08:39 PM
  #62
mhtut83's Avatar
I'm guessing it is, compared to all them big ass trucks...?
Old 01-26-2019, 03:14 AM
  #63
Diggin' that 5G Accord, BTW!
Old 01-26-2019, 05:58 AM
  #64
It isn't a super easy plug and play from what I recall...
but either way, great updates...I love following along!
Old 01-26-2019, 01:50 PM
  #65
truonghthe's Avatar
I believe the harness need to be modified on the 04-06 navi since the 07-08 wiring differently because the live traffic feature along with extra features that didn't existed for 04-06.
And for the compact parking spot, everyone here in TX love big truck (F-250 and Ram 3500, Tundra with crew cab or extended crew cab) so they want to prevent big truck park around the corner where expose to alot of traffic. My TL fit perfectly behind the yellow "compact car" line. Some time I park in the "fuel efficient vehicle" spot with my TL-S lmao.
For those who have 3 pedals TL, why this dam car is hard to down shift rev match? or is it because I am a noob at driving MT?
Old 01-26-2019, 02:41 PM
  #66
mhtut83's Avatar
HA! I was right!
I believe its due to the delay relieve valve?
Old 01-28-2019, 09:20 AM
  #67
BreezyTL's Avatar
You're a newb!
Old 01-28-2019, 10:06 AM
  #68
90foxnotch's Avatar
Ive been driving manuals since I was 16 and rarely rev match when down shifting. I think it only makes a difference if youre on some crazy twisty roads or a road course. Im a straight line kinda guy though!
Old 01-28-2019, 09:11 PM
  #69
truonghthe's Avatar
I attended AZ local meet over the weekend lmao.... Represent the Houston AZ crew we are still strong.
Lmao this is what its looks like when I need to sweep the garage floor, my neighbor keep rubbing their eyes and they though there are a car meet for sure.
Curious3GTL (02-02-2019)
Old 01-29-2019, 01:46 AM
  #70
Lots of clean TLs there! How many are yours?
Old 01-29-2019, 10:17 AM
  #71
BreezyTL's Avatar
Those are all of his... He has a damn car lot at his house!
Old 01-29-2019, 04:20 PM
  #72
truonghthe's Avatar
all of them, the wifey is driving one of the white one lol.
Thank you Breezy, I knew you are the only one who would understand me.
Old 01-29-2019, 04:57 PM
  #73
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
I got a Type-S deck lip spoiler for sale for that SSM.....just saying
But seriously you got an addiction lol
Old 01-29-2019, 06:53 PM
  #74
truonghthe's Avatar
You know that you are saving the parts so you can buy my SSM right? after all same color inside and outside.... you already has cosmetic parts laying around :P
Old 01-29-2019, 07:35 PM
  #75
Where in Houston does he live? I'm only 6 hours away... :thief:
Old 01-29-2019, 07:37 PM
  #76
This dude could make up 5 alter egos and pick a car for each one of them!
Old 01-29-2019, 08:58 PM
  #77
truonghthe's Avatar
where are you again? LA? lol I may go back there for some good as gator meat along with side road Boudin
no shit, but really I drive each car like a person at different age.
07-08 TL so so like a mid 40s years old.
07 TL-S I drive like a 25 years old getting a sport/ luxury sedan for the 1st time.
05 TL MT oh shit, how I still have my DL? lol seriously in the MT I feels like being 16 again...
RL i be like nah f*ck everything else, let me hit cruise control and enjoy the music, the seat feel so comfy tho.
Old 01-29-2019, 10:26 PM
  #78
Grew up in Metairie, LA, NOLA, about 10-15 miles west of downtown out in the burbs. Moved to southwest Mississippi in 2016, then moved to the Mississippi gulf coast in November.
Thanks for visiting and supporting LA! If you ever visit the Sip, thanks for that too. Gator meat is best west of the Atchafalaya Basin, though! Or in Lafourche (LA-FOOSH) Parish!
Way to go boudreaux! No, I'm not Cajun. I'm Diego.
Old 01-29-2019, 10:27 PM
  #79
And as of 2016, straight up southern... They're TOTALLY different, BTW!
Old 01-30-2019, 06:22 AM
  #80
I was gonna say, why no Justin!?!?
That's awesome, man...
I remember being a car hoarder!
Quick Reply: Slow restoration thread
