RDX Brake Covers installed!
#122
SSM FTW
you mean this?
![Name: 1341800631.jpg
Size: 64.0 KB](https://acurazine.com/forums/attachments/3g-tl-photograph-gallery-96/50572d1501287989-rdx-brake-covers-installed-1341800631.jpg)
dont put silicon on the center like i did LOL. realized after i did the second one that im going to run into a problem when i do my brakes. i had red rtv and too lazy to go to the store. so use black rtv and put them where the OP did. oh i also bent that middle braket down, which i think helped keep the cover flat against the caliper.
![Name: 1341800635.jpg
Size: 75.6 KB](https://acurazine.com/forums/attachments/3g-tl-photograph-gallery-96/50573d1501287989-rdx-brake-covers-installed-1341800635.jpg)
#123
you mean this?
![](http://i4.photobucket.com/albums/y128/luder917/1341800631.jpg)
![](http://i4.photobucket.com/albums/y128/luder917/1341800635.jpg)
I am kinda worried what if the cover falls later, which might give an accident
#124
iWhine S/C 6MT TL
Posting up my picture
![Name: untitled-8.jpg
Size: 25.7 KB](https://acurazine.com/forums/attachments/3g-tl-photograph-gallery-96/50571d1501287989-rdx-brake-covers-installed-untitled-8.jpg)
#125
Yea, I've had mine on for a couple days not and its not going anywhere. Just make sure you only have the silicone in the 3 spots the OP showed in the picture.
#126
Once RTV Cures it's on there for sure. RTV is used for a lot of reasons and it's main reason is for sealing as like gaskets. It's great in all sorts of temps and cleans off nice when you have to remove them. It will hold just fine if you follow my directions on page 1. I showed you where to place the RTV, if your worried about the RTV not holding then use 2x self tapper screws and secure it to your caliper bracket. DO not glue or attach the top middle tap of the caliper cover to your caliper. This cover only and I REPEAT only attaches to the caliper bracket not the caliper itself! If your doing your front calipers then yes they can only attach to the caliper but not the bracket. If your worried then don't attempt this mod but I assure you, it's the same proceedure as if you were doing those brembos covers, they are glued in place..
![](https://i231.photobucket.com/albums/ee263/typeswanabe/untitled-8.jpg)
From the picture I assume the cover has to be off the caliper holder in order to remove the caliper itself.
#129
So will these fit front and back calipers same part # and everything?? I went to order the other day and hesitated to make sure they were the right ones and now he took them off site I called Tim but had to leave a message hopefully he will let me order I'm not worried about when just want to know they are ordered
#132
TLX-S
You will most likely end up paying at the higher price they they're going for now since Tim removed them from his site to lock out anyone from ordering at the lower price.
#133
iWhine S/C 6MT TL
quanaman Looks good bro!! Make sure to post up pictures when you install them. The fronts will be a lot easier to install since it will have more to grab. Let it sit at least for 2 hours before you go driving off. Best of luck man.
#134
Man the covers look great. Seem like all the dealers are going up in price (from my research). I can't justify paying $12 each for caliper covers. If they come down I will definitely get a set
#140
A part of me wishes they didn't say Acura on them
![hide](https://acurazine.com/forums/images/smilies/hide.gif)
#144
TLX-S
G2 is higher quality and withstands anything. I've used the Dupli-color caliper kits on my previous car and it would flake no matter how much you prep and get it perfect. I used the G2 kit on my TL and its been painted for over 2 years and it still looks just like when i first painted them them.
i had originally ordered from them for that price, but was forced to pay the difference due to the price increase, so i cancelled my order.
#145
Chapter Leader (NY/NJ)
they'll send you an email asking for the remaining balance becuz price changed.. someone said that earlier... i still ordered from them as well JUST IN CASE... nothing to lose right.
#146
Well that's BS bc they obviously changed their price bc it said 11 for the last day or two AND they are probably trying to suck people in at 2 price.....I'll be pissed but yea like you said.....nothing to lose
#150
TL-S
Yup. I used the RTV recommended in this thread to install them. Red high temp, picked it up at Advance Auto for like 6 bucks.
I put a generous amount on them, then used blue painters tape to keep them on there tight while the RTV cured. The rears pretty much just fit right over the caliper. For the front, the covers are a bit too small so you have to just bend the tabs on the either side to fit them around the caliper. Its pretty much self explanitory.
I let it sit for 24 hours, then went on a 500 mile round trip. No issues
here ya go:
Front before
![Name: 43d2af93.jpg
Size: 133.3 KB](https://acurazine.com/forums/attachments/3g-tl-photograph-gallery-96/50515d1501287873-rdx-brake-covers-installed-43d2af93.jpg)
Front After
![Name: b88a65e8.jpg
Size: 136.2 KB](https://acurazine.com/forums/attachments/3g-tl-photograph-gallery-96/50516d1501287873-rdx-brake-covers-installed-b88a65e8.jpg)
Rear Before
![Name: 16ca4fe0.jpg
Size: 130.3 KB](https://acurazine.com/forums/attachments/3g-tl-photograph-gallery-96/50517d1501287873-rdx-brake-covers-installed-16ca4fe0.jpg)
Rear After
![](http://i2.photobucket.com/albums/y34/Afghandragon45/97779e5e.jpg)
The following 2 users liked this post by quanaman:
04WDPSeDaN (07-17-2012),
Undying Dreams (07-17-2012)
#151
iWhine S/C 6MT TL
Looks good bro!! Anyone else get theirs?
lights (07-18-2012)
lights (07-23-2012)
#159
so is it this?
http://www.oemacuraparts.com/acura/c...tx4-a00-acura/
just want to make sure before i order? theyll clip on right away on an 04 tl 5at with BLACK High Temp RTV?
