Quad retrofit
Quad retrofit
Did my quad retrofit a month or so back but still doing the minor things for it such as the turn signals and running into a new problem every time I fix something. But the project of choice was the Morimoto mini d2s with Morimoto 3000k bulbs. Tell me what you think!
The lens sticks out too far; looks like a fat nipple.
ABP_04TL (08-04-2011)
Yeah, the projector was a little bigger and I kind of rushed the project.
Yeah, it probably would've been better if I removed the reflector in the DRL but was rushing the project so I ended up only drilling a bigger hole through the bowl and it seemed fine so I just sealed it up. Might re-open them someday, because I think I used a little too much buytl and the headlights stick out a tad bit
your basic phillips screw driver will fit....you just have to make sure to catch the corner you can angle it do whatever but make sure your not turning for no reason. Also show us some pics of how the cut off line looks....how the lights look when off....are your blinkers working properly?
Not a bad job =)
I would have stuck the projector a little further in.
Former Sponsor
The auxiliary projector is sitting too close to the front lens, I'd push is back if I was you as over time the heat may burn a hole through your front lens or at least disfigure it.
ILLEST is just hellaflush's thing. But yeah I will be removing that sticker whenever I can paint my bumper
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
pistacio
09-26-2015 09:45 AM
