Pic Request: Drilled & Slotted rotors...
Old 09-02-2010 | 09:40 AM
Bucks13's Avatar
...on factory Type-S wheels.
I have found several pics of D/S rotors, but they've all been on aftermarket rims.
I've started to get some pulsation when braking, and the dealer just told me that my pads are still at 70% a couple weeks ago. I figured, since I'm prolly due for new rotors, I could update to the D/S, as long as they don't look ridiculous on the Type-S wheels.
Thanks!
Old 09-02-2010 | 09:48 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Rotora Rotors all around. Cross drilled and slotted with OEM pads. Ordered from Excellerate aka Josh from this forum.
Fronts
Rears
With wheel on
Old 09-02-2010 | 10:41 AM
Bucks13's Avatar
Those definitely look good, but I won't be changing my wheels (at least any time soon) so I want to make sure they'll look good with stock Type-S wheels.
Thanks for the pics though, I do love those rotors.
Old 10-20-2010 | 09:44 PM
lilsid112's Avatar
I have rotora drilled and slotted as well but on a 05 auto. My slots are pointing the opposite direction. Did my mechanic instal them incorrectly?
Old 10-20-2010 | 10:00 PM
murph145's Avatar
back when i was rockin the stockies but they now look much better behind my new rims
Old 10-20-2010 | 10:40 PM
boyhamdzui's Avatar
BMW 535i
I got one but on OEM TL not the TL-S . If you want to I will post the pics.
Old 10-21-2010 | 04:51 PM
Steven Bell's Avatar
Buck, I wanted to do this mod, but as you can see from Murph's picture, you really don't see the mod that well. I decided not to do this because I want to keep my OEM Type S wheels.
Old 10-21-2010 | 05:16 PM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
i believe he did.....i know i have brembo rotors on my integra and they say install them like 04wdpsedan's are
Old 10-22-2010 | 01:36 AM
AMUA6's Avatar
ScoobyZINE
Wait, as the car is going forward.. hypothetically the way the rotors are on now; all dust, water, etc will flow toward the center of the hub. I thought we wanted opposite? If so, then 07tl yours are installed correctly and 04WDP is backwards.
Some one please correct me if I'm wrong.
Old 10-22-2010 | 02:37 AM
nokiaboy808's Avatar
06 6spd TL BAGGED
i think it all depends on the inner veins on which way the rotor is supposed to be placed. the outside drilled/slotted pattern doesn't really matter.
Old 10-22-2010 | 03:04 PM
07TLTypeS420's Avatar
3.5L...enough said
I have some on an 04 eclipse and the manufacturers instructions were to install them like murph has his. It must be whatever way the manufacturer says to...brembo is opposite...mine stop on a dime though either way!
Old 10-22-2010 | 05:10 PM
07tl-s6spd's Avatar
well when the are spinning the circular motion would make everything fly out of the rotor....but anyway i would install the the way the manufacturer tells you...and it does depend on the way the veins go.....
MrHeeltoe
20
02-23-2023 02:54 PM
08KBP_VA
10-22-2019 02:55 PM
08_UA7_Gr33k
02-11-2016 03:17 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
