Painted Brembos in HKS livery
Was rebuilding some Brembos and thought it'd be cool to paint them in HKS livery using decals to mask. Didn't have issues with runs really, I really lightly sprayed because I was concerned the vinyl would get too saturated, worked out well!
Materials
-VHT High Temp Engine Primer - 3 medium coats
-Duplicolor High Temp Engine Purple (VHT doesnt make purple for some reason) - 3 light coats
-VHT High Temp Engine Ford Green Paint - 3 light coats
-VHT High Temp Engine Matte Black Paint - 3 light coats
-VHT High Temp Clear - 3 light coats, 1 heavy coat
When I got the calipers
Cleaned off all the brake dust, scrubbed and disassembled
Stripped down with aircraft stripper - this took days..OEM finish is tough, the blue spray paint came off easier
Aircraft stripper took it down to factory primer
Waited a few days, wiped down with alcohol and light sanding, taped up caliper bolt holes, brake pad pin, and piston seals.
Shot primer over, 3 medium coats, bleeder isnt taped off because I have new ones
Got vinyl die cuts I traced of the HKS livery
Next day, Sprayed Duplicolor high temp engine purple and waited a day before applying first batch of decals to mask the purple
Next day, Sprayed the VHT high temp engine Ford green and waited a day before applying decals with heat gun to bend around curves
Next day Sprayed VHT high temp matte black over everything
Peeled off all the decals to see how it looked
Wiped down with alcohol again, and applied brembo decal and red pin stripe to finish livery. Then sprayed clear coat. I was going to bake it to cure the paint but oven wasnt working
All done! Hardest part was just cleaning and stripping the caliper. Everything else just took patience and waiting for everything to dry. Love em!
Replacing the dust, pressure seals in the pistons, bleeders and new brake lines.
Materials
The following 2 users liked this post by DesertMistTL:
justnspace (11-12-2018),
Pair of TLs (11-24-2018)
looks great! how do you paint the calipers when they are off the car, did you hang them from wire through their threaded holes from like a tree or something?
or do you paint one side at a time and flip when dry enough?
You could use the caliper threaded hole but would have to mask off that area. Paint on threads is no bueno!
Yea, someone said painting is 90% prep, 10% paint. Painting takes 20mins, prep takes hours lol.
thanks, had time to finally do the spindle swap. i have a automatic base so i needed to gather a lot of parts before putting these brembos on
Attachment 98663
Attachment 98663
Motorsports News
06-27-2007 04:48 PM
