My Type-S full A-spec kit with roof wing
#82
get yourself a flat stick or thin putty knife to spread on the adhesive evenly on the underside of the spoiler. and definitely get some 3M adhesive remover spray. just have that and a used micro fiber towel handy for any quick clean ups you might have.
here are some pics when i installed it 3M window weld is very strong and it wont lift up the spoiler like the tape does.
#83
zaino'd
^ Man I wish I had your workmanship!
Well not really sure why my spoiler is a little different in the center... since each one is made to order, maybe they aren't all identical. Either way, when I push it against the roof (vs your placement), it looks fine. I might heat the fiberglass up a bit and bend it slightly -- hopefully this will cause less of an upward force on the ends.
#85
zaino'd
Damn edit rule...
I think I might try this instead: http://www.permatex.com/products/Aut...pose_Epoxy.htm
What do you think?
What do you think?
Suggested Applications: Ideal for complex, multi-piece assemblies. Bonds rigid materials including, ceramic, chrome, fabric, fiberglass, glass, hard plastic, metal and rubber.
#89
Is that an XLR8 exhaust, cause it doesn't look like the ATLP quad.
Where are my manners, your car looks awesome!
My TL is still sitting on stock everything. Im waiting for the summer to get most of my modifications done I just have no idea where to start
#93
Road Racer / Solo Addict
Clean clean clean!
#101
zaino'd
jptl, hope you don't mind me posting a picture in here... since you essentially guided me thru it!
I kinda like the small step... in reality, I got lazy
One of the edges was a little loose yesterday. I think its due to the warmer weather we're getting. I taped it back down with some painters tape for the next couple days because we're gonna be in the 70s! If that doesn't work, 3M WW it is!
#104
#108
I had a question about the window weld stuff... is there a similar product for painted metal... say to add a Type-S decklid without drilling holes? BTW... you just swayed me towards Sarona thanks!
#109
the 3M window weld could also be used for it. this stuff is strong i tell you. i have it on my sarona roof spoiler, i can literally grab the spoiler and tug and yank on it, and it doesnt budge! in fact it moves and sways the whole car if i do that
#110
One or Two?
you could try this i read lots of good things about it http://www.bavauto.com/fland.asp?par...source=8901003 bimmer guys have been using it to attach their trunk spoilers with it for years.
#111
Nice... I might just do that... I mean I don't mind drilling holes for the deck lid, but not if the body shop guy is going to charge me 200 for labor! Comeon! Oh in the even that I wanna remove it, is there a solution that should be used first? I mean say if you wanted to remove your wing one of these days.
Edit... he posted before me.. i didn't see it.. hahaha
#113
I Have A Meth Lab In
#115
*WFC #162*
So I was outside washing the car yesterday and noticed that the corner of the Sarona was sticking up a little. I went to pull on it to make sure the window weld was still holding and half the damn spoiler pulled up.. Not sure if I didn't put enough on there or what.. Did u use any kind of adhesion promoter?
#117
This kit is available just how he has it because I own the same one on my CBP 2008 type S I got it at the dealer and you could also get it at the Acura E store online it comes painted and ready to mount here are the part numbers you need if interested:
Front Under Body Spoiler Part #08F01-SEP-2B0B $231.00
Side Under Body Spoiler Part #08F04-SEP-2B0 $250.00.
Rear Under Body Spoiler Part #08F023-SEP-2B0B $231.00
I was confused at first when I got it because I was expecting the kit jptlo4 had on before he got this one but was very happy when it was mounted I love this kit and his ride looks sick. Sir....
#118
05 TL NBP 6spd S front
#119
yah that lip kit is available as is. its the 07-08 BASE lip kit. but the OP had a shop custom fit the 07-08 BASE front lip on his car becuz he has the TYPE S. the 07-08 BASE doesnt bolt right up to the TYPE S bumber. and Melvin2816, you have an 05 right? well they make a lipkit for your year. but its not the same front lip as the OP's front lip. IMO the 07-08 front lip is the most cleanest lip EVAR!
