Lic Plates with LED's
LyfeIs what you make it!
Installed the bulbs I ordered from Superbrightled.com. Not as bright as the Lexus lights but I'm pretty satisfied.
![](http://lyfeis.com/Pictures/platesfront.gif)
![](http://lyfeis.com/Pictures/platesside.gif)
What do you think?
What do you think?
AZ Community Team
Received 7,770 Likes
Originally Posted by princelybug
I got the 921-x9 LED Wedge Base Bulbs from superbrightleds in my car, which did you install? Looks great! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Same here. I don't want a *really* bright License Plate light. I like 'em.
OP: Nice Job!! Lookin' good.
Tri State ViP Crew
yea for a real bright look the cold cathode mod is the way to go.
But I personally like the look of the LED's. It has a very nice and clean look and its not too bright.
![](http://i13.photobucket.com/albums/a268/evomacky/TL_LED01.jpg)
and to show just how bright they are, check out the light cutoff at the floor from the rear:
![](http://i13.photobucket.com/albums/a268/evomacky/TL_LED02.jpg)
to the OP: not bad at all. were they blue or white?
~Da Nocturnal Cheetah~
Looks good Lyfe, enough where you don't need CC. I thought of doing my lights in CC (I have the lights), but haven't yet because I really don't want the popo zooming in on my plates. LOL! Plus it might mess up my stealth look!
Originally Posted by darksom1
Looks good Lyfe, enough where you don't need CC. I thought of doing my lights in CC (I have the lights), but haven't yet because I really don't want the popo zooming in on my plates. LOL! Plus it might mess up my stealth look! ![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
Originally Posted by blazinginder
How'd you install the bulbs...a lot of work ?
anyone knows which kind of connector and led I can use for the reverse light? some specs will be helpful... thanx
My username is lame
hello. For those who bought those LEDS from superbrightleds, those bulbs are 12w, and i took off the harness for the rear plates, and it says 5w. Will this cause any heat problems? thanks.
so currently inside my car i have 1led bulbs. I didn't know i could put 4, or 6. So i was planning on buying 2x 6led bulbs and then putting those two in the front map lights. and taking those 1 led bulbs and putting them in the rear for the plates. What do you guys think? will it not be bright enough for the plates?
AZ Community Team
Originally Posted by psheu
anyone knows which kind of connector and led I can use for the reverse light? some specs will be helpful... thanx![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Using the backup camera, the light out put is good and clear (IMO better than stock). Only had them a few months, so cannot comment on long term durability.
Originally Posted by Bearcat94
Superbright LED's 921-x12 Wedge Base White LED is what I've got.
They r really easy to do.... just remove partial the trunk lid lining (few clips, and one screw to remove), unclip the plastic light holder housing, pop the old bulbs out and insert the new one in, put everything back.... it took me <5 min in the dark to do this:P....
I have cold cathodes, not LEDs psheu. At least that is what I was saying I hadn't installed yet.
there r 5 round plastic clips, 2 strips of rubber paddings and 1 screw and 1 plastic latch cover to remove to un-attach part of the lining (leave the 2 round rubber stoppers and the trunk latch alone). after that peal the lining back and expose the back of the license plate holder. you'll see the top have 2 light housing. on each housing, hold down both sides of it and pull it away from the clip that holds it in place you'll get to the light bulbs. the reason i choose the led bulbs is b/c it's an even swap. with cold cathodes, the mounting might be a bit different.
My username is lame
Originally Posted by sixsixfour
the LEDs I got look just as bright as the cold cathodes but is easier to install:
hey what kind of lights do you have inside?
AZ Community Team
same as the ones on the license plate, reverse lights and door lights. bright and white eh? ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Also, you pics look over-exposed; you can see the "burn in" around the side-markers. Are the pics an accurate representation of live and in person?
LIST/RAMEN/WING MAHSTA 짱
Originally Posted by LyfeIs
Those are the WLED 4-LED bulbs. I thought they would be brighter. If I would have known better, I would have bought the 9 or 12 led's. Not complaining.
FWIW, the glove box and center console light bulbs can be replaced with the "74" bulbs from superbrightleds.com, but the base of the bulb housing has to be filed down a bit, and rounded off. (These are a bit of a pain).
I looked through the thread and don't see where you say which bulb and base or source. Can you elaborate?
The shots taken were at 1/15th second at F/6.3 ISO 400 on a tripod. They are as accurate I can get on a DSLR.
WDP 07 TL Type S
What is the difference between polarized and non polarized? The Wedge base 921-x9 LEDs are polarized and the 921-x12 are non polarized according to Superbrightleds website. I'am thinking of going with the 921x12 LEDs if they are brighter than the 921-x9 LEDs. The Luxer1 LEDs look awesome. It would be nice to have a Super Autobacs here in Washington and I would pick up a pair. I also found the Luxer1 LEDs on Ebay for $14.95 for a set of different sizes plus shipping for $12.50, but the peeps who are selling it do not accept Pay-pal. Kind of weary of that. Saw the back plate lighting of a Lexus the other day and it looked cool and would like to have that look. Thanks for all of your help.
I also bought the 9-LED unit and put that in the trunk. that should fit the interior domes no problem, as the 9-LED fits the trunk light casing, albeit with a snug fit.
AZ Community Team
Originally Posted by lucastypeS
What is the difference between polarized and non polarized? The Wedge base 921-x9 LEDs are polarized and the 921-x12 are non polarized according to Superbrightleds website. I'am thinking of going with the 921x12 LEDs if they are brighter than the 921-x9 LEDs. The Luxer1 LEDs look awesome. It would be nice to have a Super Autobacs here in Washington and I would pick up a pair. I also found the Luxer1 LEDs on Ebay for $14.95 for a set of different sizes plus shipping for $12.50, but the peeps who are selling it do not accept Pay-pal. Kind of weary of that. Saw the back plate lighting of a Lexus the other day and it looked cool and would like to have that look. Thanks for all of your help. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Don't remember for sure which is which but:
One will go into the socket either "right side up" or "upside down" and still work (I think that's non-polarized).
The other will only work when it is "right side up" (I think that's the polarized one). With this one, you gotta make sure you've got the bulb in correctly before you put eveything back together.
I want to mod my license plate too. I like the ones used by sixsixfour. He mentioned 194 LED so I went to ebay. There were tons, but I have no idea which ones will fit our cars. Can someone take a look for me or all of them will fit? Thanks!! Here's the link
http://search.ebay.com/search/search...LED&category0=
http://cgi.ebay.com/ebaymotors/Lot-o...spagenameZWDVW
#GOBULLS
I was at Lowes and Home Depot today and I happened to find xenon 5w 12v wedge bulbs used for home light fixtures. Its the same as a 168 bulb. At Home Depot it comes with two in a package for like $6. I wonder how these would look in the license plate?
Here's a link
http://www.lowes.com/lowes/lkn?actio...-12&lpage=none
Here's a link
Nice pics but i think that the cold cathodes are a little brighter. I have them on my car. it wasn't that hard of a mod to do yourself and the cold cathode bulbs only cost like 15. Thats about how much a set of led's cost.
