Interior LED conversion 99% complete
Old 01-28-2011, 04:54 PM
  #41
IDSTL's Avatar
so bright man.........
Old 01-28-2011, 07:40 PM
  #42
Slythslyr
spcslyusarmy's Avatar
Ok, so pretty sweet i got all my stuff in the mail...
here are the ZKW-R lenses:
[IMG][/IMG]
here is the HID kit for my foglights (3K) purchased from V-LEDS:
[IMG][/IMG]
Here is the harness to make my fogs independent:
[IMG][/IMG]
here are the Phillips 85122+ bulbs from the retrofit source:
[IMG][/IMG]
OH and just for shits and gigs here is my old Yamaha R1:
[IMG][/IMG]
[IMG][/IMG]
and the Old STI:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
OK thats all for now!!!
Old 01-28-2011, 07:53 PM
  #43
2011 ZCP E92 M3!!
dave_ramkumar's Avatar
looks really good , was it hard to do?
Old 01-28-2011, 08:07 PM
  #44
Slythslyr
i havent installed any of them yet, but its not that hard.. i installed almost the same stuff on my STI and i put in an HID kit in my R1.. the only thing i plan on having trouble with is the lenses..not sure how im supposed to turn them on and rotate the lense to focus it!! ill give it a try here soon though.
Old 01-29-2011, 03:06 PM
  #45
Slythslyr
UUUGGH, i wish i had a place to install all this stuff...i also wish the wife would go away for about a day or two...she doesnt really know about any of this stuff...haha
Old 01-29-2011, 07:58 PM
  #46
anx1300c's Avatar
Thanks for this thread! You inspired me to order basically all the same LED's, except I went with 5k white and the angled 6 light ones for the map/vanity. Was going to go with the 105 lm plate lights, but decided I didn't want passenger jets seeing my plate from 30,000'.
Only real difference is that I went with this for the trunk:
http://www.v-leds.com/Interior-LED/D...08401-1-2.html
I figured 35 lm would be a little brighter for the trunk, which is good.
Nice R1 too. Had my buddy's up to 181 mph indicated; was still doing an honest 170-175. What a rush; I miss sportbikes.
Old 01-29-2011, 08:15 PM
  #47
Slythslyr
Sweet deal man.. Glad i could help. I will eventually get the right one for the trunk, i just happen to order too many of the other kind so i just put it in there. I will be installing all of the other lighting stuff here shortly..i cant wait.
Old 01-29-2011, 08:28 PM
  #48
spends his lunch $ on his
04socalTL's Avatar
how did you change the vanity lights? i tried but i couldn't take the plastic cover off to get at the bulb
Old 01-29-2011, 08:50 PM
  #49
2014 Jeep SRT
ebelp's Avatar
Received 1,615 Likes on 1,030 Posts
Ooo I thought their 3k h8 hid fog kits were on back order...be sure to post pics after you get them installed. I've been seriously considering that kit instead of the 6k kit that most people have.
My ZKW-R lenses are in the mail. I've been doing a lot of research. I don't think you rotate them to focus them. I believe bending the cutoff shield is how you fine-tune the beams.
Btw, nice to see another former STi owner on here.
Old 01-29-2011, 08:51 PM
  #50
Slythslyr
those things suck...on both lights you have to pry in between the metal plate and the plastic cover on the inside towards the center of the car..use a small screwdriver and push very lightly in between the two and once there is a gap just pull hard on it. It will come off but if you replaced the trunk bulb the cover is the same..The little plastic tab breaks easily so be careful. I broke my drivers side but super glued it back in place..hope that helps.
i PM'ed AckTL05 about the ZKWr's and he said just put it in the way it is and try a spacer of cardboard like a cereal box to space it out to get the razor sharp cutoff..
oh ya about the STI, i regret it everyday.. i sold it to get a Bike and then sold the bike and got the Acura because i was changing duty stations from kentucky to alabama.. I wanted something nice but wish i could have found the KBP in 6 speed..lol
Old 01-29-2011, 09:03 PM
  #51
2014 Jeep SRT
ebelp's Avatar
Use a small flat head screwdriver...gently.
Old 01-29-2011, 09:11 PM
  #52
2014 Jeep SRT
ebelp's Avatar
See that's what I thought about the ZKW-R's too, but several people on the hid planet forums said they don't even need a spacer. Only the real ZKW's do. And they said the spacer's purpose is to hold the lens in place more securely.
I sent JnC a PM about it. Waiting for his reply...
Old 01-29-2011, 09:13 PM
  #53
Slythslyr
ya man, let me know what u find out.
Old 01-30-2011, 05:34 PM
  #54
Slythslyr
installed my FOG lights today, with the independent switch!! once i finish everything up ill take some pics and post them..probably tomorrow!!
Old 01-30-2011, 08:52 PM
  #55
2014 Jeep SRT
ebelp's Avatar
Awesome. Can't wait to see the pics. Did you do the independent fog DIY that uses the stock fog switch?
Old 01-30-2011, 10:11 PM
  #56
blackanese's Avatar
Good work! I did this to my old GS400. What a difference it makes.
Old 01-30-2011, 10:16 PM
  #57
Slythslyr
Yes i did, unfortunately i havent been able to finish it up yet.. everything in the hood area is installed. i plan on wiring the last two wires to the factory switch using this DIY I needed to run to the store to grab stuff for dinner and it started raining so tomorrow..
Old 02-01-2011, 06:32 PM
  #58
Slythslyr
Ok, so i finished my HID fog light install...notice the DRL's on, the key is just in the ignition..Tell me what you think!!
I am wondering wether or not i should take out the little metal shroud inside the foglight housing.. it covers up the bulb a bit...any thoughts?
Old 02-01-2011, 07:15 PM
  #59
1islandparadise's Avatar
Looks great man! I wouldn't remove the metal piece in the fogs. Pull fuse #3 (drl bulb)...haha, no but serious it looks very nice!
Old 02-01-2011, 08:59 PM
  #60
CR
Stylinhonda's Avatar
Might be a dumb question, but on their web site when it says
$7.99
V-LEDS Part ID: 194_5_SMT_W_6K
# In Package: 1 Pair
That means you get 2 lights (a pair) for $7.99.......not $7.99 each?
Old 02-01-2011, 09:02 PM
  #61
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
$7.99
You get 2 bulbs (1 pair) for said price, which is $7.99 in this case.
Not $7.99 each bulb =P
Old 02-01-2011, 09:05 PM
  #62
CR
ha thanks, just wanted to make sure!
Old 02-01-2011, 09:08 PM
  #63
No problem
Just ordered those bulbs (194_5_SMT_W_6) myself, actually =)
Ordered 2 pairs (4 bulbs); 2 bulbs for the doors, and 2 bulbs for the back seat overhead lights.
Should be here (Canada) in 3 days max.
So excited =P
Old 02-01-2011, 09:22 PM
  #64
CR
Sweet. My first try at LED's. Just ordered
- V-LEDS HID WHITE 6 LED M-SMT FLANK BULBS 194 168 158 2825
- 2 HID 6K WHITE HIGH POWER LICENSE PLATE MAP PARKING LED BULBS 194 168 158
- 2 HID 6K WHITE SMT 5 LED LIGHT BULBS 194 168 158 2821
- V-LEDS 6K WHITE 1W HP LED DOME LIGHT BULB 3022 3021 29MM
For my RDX. Was going to do the reverse lights, but there like $80
Old 02-01-2011, 09:30 PM
  #65
2014 Jeep SRT
ebelp's Avatar
Looks great! It's funny how they look blue in the housing, but the beam pattern is very yellow...does it look like that in person or is it just the camera? Are the fogs bright enough to drive with if you had to?
Old 02-02-2011, 04:51 AM
  #66
Slythslyr
I know i thought the same thing.. But they are very yellow in person. the camera actually took an exact replica of what they look like. not sure if i can drive with them at night with just the foglights. Ill try it out in a few min.
Oh and im glad i could help other people with deciding on what lights to use. I also said the same thing about the reverse lights....$80 Yikes!!
Old 02-02-2011, 09:29 AM
  #67
2014 Jeep SRT
ebelp's Avatar
These are the ones I have now:
http://www.v-leds.com/Exterior-LED/B...35716-1-2.html
Not really impressed with them. Might upgrade to these, but the price is still pretty steep in my opinion:
http://www.v-leds.com/Exterior-LED/P...26829-1-2.html
Old 02-02-2011, 01:23 PM
  #68
Slythslyr
OH and FYI for anyone that does the independent Switch mod for their Fogs, the foglight light on the dashboard will no longer light up no matter what setting the headlights are in!
Old 02-07-2011, 08:43 PM
  #69
Slythslyr
Off topic, but i just ordered some Michelin Pilot Sport A/S plus in 255/40/ZR17, got them cheaper than anywhere else by going on www.discounttiredirect.com. Contact this guy and tell him Chris Sylvestre sent you. He can get you almost any tire cheaper than anywhere else..
Kyle Kennedy
Retail Sales
Discount Tire Direct
800-589-6789 ext. 51836
(602)735-1800 ext. 51836
Old 02-08-2011, 02:25 AM
  #70
9th Gear
frase1ew's Avatar
Are these interior lights just plug and play?
Old 02-08-2011, 05:12 AM
  #71
Slythslyr
Yes they are, just pop out the old one and pop in the new one.. do verify they turn on before putting any cover back on, because the polarity does matter, but its real easy, if it doesnt work one way just flip it around and it should work..
Old 02-08-2011, 06:01 AM
  #72
friggintiger's Avatar
nice
Old 02-08-2011, 12:53 PM
  #73
wishing for a GT-R
tinad2004's Avatar
love the LEDs
Old 02-10-2011, 09:24 PM
  #74
Slythslyr
Tires are getting installed tomorrow morning...
Old 02-14-2011, 09:47 PM
  #75
2014 Jeep SRT
ebelp's Avatar
New wheels too?
Old 02-15-2011, 08:35 PM
  #76
Slythslyr
i wish!!! the tires look pretty awesome though.. ill post up some pics tomorrow
Old 02-17-2011, 07:40 PM
  #77
brandon1221's Avatar
nice, looks much brighter than stock
Old 02-17-2011, 08:50 PM
  #78
Slythslyr
New Tires
Heres just a couple quick crappy Iphone pics in the dark of only one wheel...lol
Yes i know that is a lot of Tire Shine, but i sprayed it and didnt wipe off the excess...SUE me!! haha
Old 02-23-2011, 12:23 AM
  #79
Sir Drake's Avatar
Here is my license plate...got the led from unqiuestyleracing.com
Old 02-23-2011, 12:28 AM
  #80
Sir Drake's Avatar
Also, I had problems at first when I was reinstalling the housing from the outside with the light harness attached...I re-installed the leds lights by taking off the trunk liner...I popped the light housing into place from the outside and from the inside of the trunk I clipped the led and harness into the housing...worked perfect.
Quick Reply: Interior LED conversion 99% complete
