Is there a reason there's a tiny gap, bigger than the others in those locations? Is it because of the middle separator in the vents? I'm wondering if you could somehow improve it slightly haha
Good job though. Not my style however (got DRL in Canada already, fogs are US).
I wasn't sure about the DLRs at first, but they kind of grew on me after a few days.
I thought about just running a straight line of LEDs across the center rib of the inserts by the fog lights, but I thought that would look too much like some common Toyotas & other cars with early LED DLRs.
IDK, they may stay, they may go, I may modify them. As far as the Inspire fogs, the stock HID Projectors are so damn good that the fogs don't add as much as I thought.
Look into LED strips that don't have the individual LED's and it might look better. TheREtrofitSource had them for a while but they seem to be sold out
Yeah, the center separator is kind of a problem, and the LED strips have plug ends all at the same end. When you run them top & bottom, they are basically reversed & the plugs are at different ends, which causes the gap. The LED strips have the lights at right angle to the backing tape-they are actually on the front facing edge instead of opposite the tape side.
Fogs light up right in front of your car in clear conditions but obviously where they really work is in thick fog. Amber/yellow cut right through it where headlights with a whiter color will shine back at you and diminish your night vision.
