How I removed etched in hard water stains!
Recently picked an 08WDP Type-S. It had a report of being side swiped on driver side. Oh well. Better deal for me as car and repaired area look just about perfect. Got it with 145k miles for $5k. Been doing simple routine maintenance so no biggie. I have had it a little over a month and so far I have.....
Cleaned headlights- free
Changed tranny fluid 2x- $70
Changed oil 2x full synthetic-$40
Replaced front pads, had some laying around from so many TLs lol-$free
Replaced APP sensor-$40 pick a part shop off 07
Replaced gas cap with OEM-$6
Cleaned engine bay covers-free
Need new leather for front passenger seat
New tint installed 20%
New battery -$138
Couldn't figure out the f'd up paint though.
Initially thought it was simple orange cut pad, compound, polish and wax.....NOPE!
I wonder how long the car sat in the sun dirty as hell before it was repaired.
researched and came up with having to wet sand
see tools and supplies below. For an amateur I think it came out well
Wet sand 2500, 3000, orange cut pad, blue polish pad, wax, buffed, wiped....5hrs........results!
Products
Tried to get an angle to show water marks.
This is how 100% of the hood, trunk, roof looked.
Better images of how bad it is
Yuck. Coarse as rice
Wet sanding
Coming clean
Thing of beauty with water beading
Depth on trunk
Paint has depth again. Hood life lol
Amateur job not to terrible
Pheeeeew finally no more etchings
New battery -$138
Products
Wet sanding
Coming clean
Depth on trunk
Slpr04UA6 (08-25-2019)
You bought another TL?
You have a problem, Ghost.
That came out great! I'm surprised you could do all of that in 5 hours.
What typically removes water spots? I'm planning on doing detailing again an amping up my skills from what I used to do.
What step is primary in removing the water spots, or like, 80-90% of them?
Did you combine the water spot removal with the paint correction regiment? Did the 5 hours include wash/clay/wax time too?
I think I turned this into an interview, sorry... Just looking to learn! But that car looks 100% better!
I DO. LOL
5 hours consisted on the trunk, roof and hood only. Although 100% of the car wasn't covered I still have glass and the top part of the right side doors and rear fender to do. So I still have a ways to go but for what was the obvious when you saw the paint, it has been corrected.
What typically removes water spots? Day old or week old spots just a wash or simple compound will get 'er done. I tried that and it didn't come close to removal. I'm planning on doing detailing again an amping up my skills from what I used to do. Youtube and practice
What step is primary in removing the water spots, or like, 80-90% of them? For me the Primary step all along was wet-sanding because that is for extreme cases which mine qualified for. The mineral deposits had become apart of my clear coat so it needed to be taken down to remove.
Did you combine the water spot removal with the paint correction regiment? Did the 5 hours include wash/clay/wax time too? I had previously clay barred and although I pulled grime it did nothing for the water stains. Essentially ithe process is rolled into one because when you cut the clear you have to then clean it, polish it and wax to protect. Else you leave it exposed to the elements. Water just rolls off my panels now. If you wash your car and rinse and before you can finish completely rinsing, your car has already dried itself (LOL) you have some dirty ass paint.
I DO. LOL
Thanks! I've been trying to gather information on paint correction. I need to know it, but I'm more of an interior guy.
How many TL's have you bought now?
Planning on keeping any of them or are you just trying to save as many TL's before they get trashed.
Either way, I sure as hell wished more people did what you do. It would make finding a decades old used car WAY easier.
Looks great. Diamond Cut #10 is killer stuff. Even works better on removing haze from headlights than the actual overly abrasive products they sell specifically for hazy headlights... go figure.
But I have the same setup. Mcquairs #3 cut and #10 cut, and as of lately I claybar'd mine and used Mcquairs ceramic Hyrbid wax, and topped with Maquairs Gold Carnuba wax.
You might not have needed to wetsand at all. because the #10 cut with a WOOL pad will cut. Especially if you have a machine.. Then switch to #10 with a microfiber pad and it will make a high gloss. Then switch to #3 (4 or 5) cut and a microfiber pad and that will finish it off. Last step wax.
I would only wetsand if you have orange peel or "fish eyed" clear coat.
Midnight Mystery (10-26-2019)
