Headlight Beam...is this Normal?
Coolest A-zine Member
Posted in another thread, but was told this kind of crowd is in here. Hopefully I can get some help! Thanks in advance
Headlights look off to you? I don't think they're supposed to swing up like that on the passenger side. Does my crossover area or whatever it's called in the middle look okay though? If these pics are bad I'll try to get some better one's soon.
I personally have never tampered with the actual lens or opened up the headlight, but I did buy it used. I don't think he would have messed with it either, but thought I'd throw that out there.
^What he said. The cutoff is supposed to step up like that so that you don't blind oncoming traffic on the left, but can still read road signs on the right. However the two beams should overlap so that it looks like there is only one step up.
Here's a good link on how to do the aiming:
http://www.popularmechanics.com/cars...repair/1347221
This how-to might be a little more appropriate since it applies to HID headlights specifically: http://www.hidplanet.com/forums/show...HID-headlights
They look fine to me. You may need to raise them a little bit. Check the measurements again to make sure they are where they're supposed to be. It explains in the owners manual how the lights should be aligned. This is what mine look like.
If I remember correctly, beam height (the top color band) is supposed to be at the same height as the middle of the HID lens when parked at 20ft away from a wall. Might be 25ft..I dunno.
I probably need to pick up some new bulbs as these are likely the factory bulbs with 118k on them lol
i decided to post in this thread because i have a similar question.
my cutoff isnt clean like others that ive seen on here and i'm wondering if i can adjust that without taking aprt the headlight. i cant believe my headlights are that far off since i have an 08 with low miles and the lights are oem.
any thoughts / help will be useful.
thanks
thanks
Also, check this site out.
http://www.jvxdriver.com/TL%20Lens%20Swap%20Comparison%20Oem%20vs.%20ZKW%20 vs.%20ZKW-R.htm
No, their is now way around opening the headlight. They are clamped in place in the projector. It's an extremely easy process. It would probably take you an hour or two to do the whole proccess. Opening headlights, swap out lenses, tune the lenses, seal headlights.
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
rockyboy
Oct 2, 2015 10:45 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
