Desert Mist TL Build
#86
The mileage info is all saved in a separate computer/ in the PCM right? So swapping clusters doesn't require a trip to the dealer for mileage programming?
I probably wont ever do a type-s swap because I really like my 2008 cluster (I love the blue). I am just curious lol.
I love that you did both the cluster AND that separate display, it looks awesome!
#87
If I were you I'd just pick up the TL-S outer bezel with the rings-- it's direct drop in!
#89
I think that color is called Bold Beige Metallic, and was only offered on 2008 base models.
Personally I like the Desert Mist a lot better, though I'm not sure I've ever actually seen the bold beige in person lol.
Cool to see the two side by side like that!
#90
I saw one BBM before an old guy left acura dealer for service he just can't keep staring at my MRP lol.
#91
Received 6,470 Likes
#93
wow, it'll look full type-s!
looking forward to it being on the car
#94
installed the TL-S Lights
04-05 use a bigger ballast that wont fit on the TL-S headlight, so I had to pick up (2) ballasts with the "W3T19371" part number. 06-08 use this slimmer ballast.
I used Silva95Teg's tip to convert my OEM parking light to fit inside the TL-S stripped out oem socket. Basically use the stock tl-s socket as a sleeve.
https://acurazine.com/forums/third-g...s-base-814655/
My DRLs arent wired, they just act as fogs like normal but I understand they melt the housing so I wont be using them as fogs but will make a DRL harness to run them at low wattage as usual.
silverTL6 (02-13-2020)
#98
finish front end with the grill.
#99
#103
good stuff man, TL is looking real clean keep up the work on it!! I thought about changing the cluster gauge but thought they only came in red for some weird reason lol and true every time i see this color way on the streets it's usually some old woman LOL. I've rarely seen the green lurking around too.
#104
picked up a tl-s cluster and clock, real simple install
since i have an 05 with no tpms, the TPMS error shows up on the MID when i start the car, but i just click out of it. The notification icon was always lit and the airbag sensor light is on when I did this so I opened up the cluster and taped off the notification icon and the airbag icon. I can live with the TPMS warning as this looks sick!
everything works!
this is the only thing that shows when i start the car. other than that, nothing different form my old stock cluster!
everything works!
nightwing17 (07-16-2015)
#106
Keep up the mods, she's turning into a beauty! looking forward to seeing some more!
#108
^^^ Looks good!
#110
Looks good-I've got the H&R Sports Springs and really like them.
DesertMistTL (01-03-2016)
#115
everything works!
everything works!
It you don't mind me asking, how where you able to clear that airbag sensor light? Is it dangerous if it stays on? (I really don't mind the sensor light being on I just want to know if it is safe)
#116
Taken from another thread
"For and 04-06 TL (UA6), Of course you will need to replace the SRS unit with an 07/08 (UA7) SRS unit and move 3 pins, and you will need to replace the OPDS brain in the passenger seat. The UA6 HELM ETM calls the ODS brain the ODS unit. But the UA7 HELM ETM calls the brain OPDS unit. The UA6 and UA7 HELM ETM call the OPDS sensors by the same name. The sensors in the seat talks to the OPDS/ODS, and the OPDS/ODS talks to the SRS unit. And the SRS unit talks to everything. Which is why there are many pins on the SRS unit. So LABEL every wire before you cut! Be prepared, and by some cable labels from FRY’s or somewhere. I uses silver duct tape and scotch tape. That wasn’t the best choice. Frys has real cable labels. (And you definitely need some kind of labeling system for any splicing that I mention below. But you may not have to splice if you get a nice quality passenger seat to replace the one you have. Read on below.)
#117
havent posted in a while
s4play rear diffuser from is250
Attachment 100880
Carbon fiber wrapped TL-S cluster bezel
metal petals
Type-s Honecomb grill + blacked out center grill piece
New power steering seals and clean
Fixed my splash guard since i ripped it off when i forgot a clip'
Last shot of her chilling + bought 07-08 blinking side mirrors color matched OEM--was fun to wire... just ordered chrome hood and V grill trim. Also got honeycomb lower mesh im going to fit behind my asepcs
Attachment 100880
metal petals
#118
^^^ Everything looks good, especially the Carbon Fiber (naturally)......
#119
Nice updates!
Did you have to cut-to-fit the Type S front grille? I thought I read here on AZ the Type S is taller and has to be trimmed down or a section in the middle has to be cut out? Assuming I remembered that correctly, would that mean the dark chrome hood and front grille trims are going to require cutting too?
Can't wait to see the next updates! I love the progress, your TL is a one of a kind!
#120
Nice updates!
https://acurazine.com/forums/third-g...-06-tl-817615/
I didnt end up epoxying any of it together. Kind of just attached it to the bumper and called it a day.
The hood piece will fit but the V-grille can't since it's taller then the 04-06.
I just got chrome hood and v-grille off ebay to try it out.
im also playing around with this f1 rear brake light. not sure if i like it, just mocked it up
