Your ultimate guide to OEM TL flywheels and clutches
#81
Brock
Ahh, I see. If you don't have another flywheel to compare, the J32 crank mating surface to clutch mounting surface should be 54 mm distance.
#82
Wow, that actually helped a lot. Thanks. There's only one problem: the distance on my flywheel is exactly what you specified, so I'm a bit lost. By any chance, maybe you also know what the gap is between the ring gear and the engine block?
#83
Hey Euro Quick Question
Can I combine this clutch with my stock OEM flywheel, and be just fine for now? At least until I get money to upgrade flywheel, but then I won't be able to use this clutch with a single mass flywheel....would I?
Clutch I mentioned, that works with OEM Flywheel:
08028-HDFF-R - Clutch Masters FX350 Clutch Kit - Excelerate Performance - European, Exotic and Japanese Performance Specialists!!
Thank you for your time,
Vega
SerpentX
#84
Brock
Put the pressure plate on the flywheel without the disc and measure the total stack-up height, from the crank mating surface of the flywheel,
to the part of the pressure plate that sticks out the furthest. If it's more than 93 mm, then the pressure plate is interfering with the clutch case.
#85
You haven't ruled out the new pressure plate yet.
#86
Brock
Originally Posted by SerpentX
Love the car BTW, I have a 2005 Acura TL 6 speed, and the clutch will start to slip in only on a spirited 2nd to 3rd shift, or 3rd to 4th. However not in any other gear or during normal driving, instead of spirited. I plan on getting a new clutch, and it is a weekend car, not my daily, but I am stuck with what I want and what I can afford. Do you have a recommendation, I would love to upgrade flywheel to Single Mass, but that takes the total up into the $1200+ range. I found a clutch that would work with the stock flywheel, but do you think is worth it, or just continue to save up? I will be using the car for spirited driving on the weekends, and some local circuit racing every now and then.
Vega
SerpentX
Vega
SerpentX
Few Honda/Acura V6 enthusiasts are aware of the CMC delay valve. Fortunately there is a direct swap available without the delay valve. Honda part number 46920-S5A-G06.
Accord_V6_400m (06-20-2018)
#87
#88
Brock
So do you maybe by any off chance know the gap between the ring gear and engine block? I'll take the flywheel in for a 1-2 mm grind tomorrow, and I'll factor in 0,5 mil difference to compensate the thickness of the clutch disc (so that they grind the PP mounting surface 0,5 mil less than the friction surface).
#90
Have you removed the check valve in the clutch slave cylinder? If yes, then have you swapped the clutch master cylinder with one that doesn't have a delay valve?
#91
Brock
If you are using the stock flywheel, then just use a stock clutch kit. If you aren't boosted, then you don't need a beefier clutch.
Some people think they need an uprated clutch if they are going to do some track events, but that's a misconception. The clutch
clamping load and friction coefficient simply need to handle the engine torque. A track event could potentially cause more heating
of the clutch components, but it depends on several factors. The disc material is probably the most significant factor when it comes
to heat dissipation. Some companies utilize discs with Kevlar, but it comes at a cost. The engagement is more aggressive, meaning
it's more "bitey" and is kind of annoying to drive on the street. I personally prefer organic material as it has a smooth engagement.
#92
Ok, no I am not boosted, just minor bolt on's and then plan on adding some more, but the TL shouldn't get over 300hp without boosting. I just want something that can take punishment on the track but run like a daily, as long as it can hold up for another 60k and the quick 2 to 3 shifts. This stock clutch lasted 104k, so not bad I say... So I am going to check the stock Flywheel, (which should be fine) and replace the clutch set, with a decent OEM like Exedy. Isn't LUK also OEM or am I wrong? Just as long as it
#93
Brock
The stock clutch and flywheel are made by LuK. Most, if not all, stock clutch kits are just re-branded LuK parts.
Your current clutch may be fine. Evaluate it after replacing slave cylinder and clutch master cylinder.
DMZ (03-10-2019)
#94
#95
Brock
Hey man. Can I ask you a question? Is it possible to replace the clutch fork without removing the box on our 6-speeds?
#96
I actually tried doing it yesterday, the fork can, in fact, be removed through the hole in the clutch case, but it seems to be impossible to detach it without sliding the release bearing away from the transmission. So I'm gonna say no.
#98
4drs just wanna have fun!
Suprised to see that the honda part actually costs more then the original Acura CMC but I'll look into how this unit compares to the Ktune CMC. I'll ask them who makes their CMC's for them.
#99
Brock
A word of caution about using the non-damped CMC. The damper is there for NVH. Without it you will experience pedal buzz. If you have a dual-mass flywheel (stock) then it's minimal.
If you have an aluminum flywheel such as an Aasco flywheel, then it could be objectionable. I have an Aasco flywheel and it's a bit annoying at higher revs, but I can live with it. The overall
shifting process is much more precise without the damper. Generally speaking, the damper slows down pressure increases/decreases, thereby greatly reducing vibration transmitted through
the pressurized fluid.
A clutch with higher clamping load will result in the damper slowing the pressure increase/decrease even more and may result in the trans not wanting to go into gear and thus missed shifts.
Some people experience this even with a stock clutch, so a non-damped CMC is advantageous for spirited driving and racing. You just have to decide if you can tolerate the pedal buzz.
The Civic CMC is made by Nissin and can be found through aftermarket parts retailers such as Partbull for much less. I can verify that the Adler part is in fact a Nissin part.
The outlet fitting on the non-damped CMC sits lower, so a bit of clutch line tweaking is needed. Actually, quite a bit of tweaking, but it fits fine. Just make sure it clears the brake booster
and doesn't touch the body. It's isolated for a reason. I highly recommend removing the brake booster. It makes the CMC swap substantially easier.
rockstar143 (08-16-2021)
#100
Latent car nut
Received 2,005 Likes
When you describe the potential clutch pedal buzz, are you referring to a 4-Cylinder car or a car like the TL with a V6 motor? I ask because I can imagine a huge difference in vibrational impulses between the two; what with the classic "torque reversals" of 4-cylinder/4-stroke engines being rather severs and such torque gaps in 6-cylinder/4-stroke engines being virtually eliminated.
#101
i'll go look up the part on partbull then, i was also considering an Exedy unit for like $30shipped.
How did you go about verifying that the adler part was indeed made by Nissin? was their Nissin name stamped on it or some other way?
#102
Brock
The Civic CMC outlet fitting is the same except for the thread. The Civic has a 12mm fitting on the clutch line and all the damped applications have a 10mm fitting.
It's probably a good idea to get a new fitting if doing a CMC swap.
The Nissin logo is cast into the CMC body. I bought one from a Honda dealer and one from Partbull. They are identical and both made by Nissin.
Here is what it looks like with the non-damped CMC:
#103
J37 and J32.
Ever take apart the stock CMC to see how the internals look like? I plan on doing so when put in the Civic master.
#104
Brock
The two connector fittings are the same on the end that inserts into the CMC. The threaded fittings on the clutch line are different between the Civic and the damped applications.
I still have the original CMC but haven't taken it apart.
The Civic connector fitting is the black one, both are aluminum. The new CMC will come with a new seal but you will need another U-clip. You should install the connector fitting
into the CMC before installing in the vehicle because it's impossible to get at the U-clip end to spread it apart once installed.
Accord_V6_400m (06-21-2018)
#105
Would you recommend a new clutch line connector as opposed to reusing the one on the old CMC? Did it get a little stripped in the removal process? Thinking of getting the braided line from the CMC to slave now.
#106
Brock
You being in SoCal, your original connector fitting is probably fine. My TSX had 6 winters on it before I bought it, so I always get new parts before working on it just in case.
Below are my notes from the CMC swap (assuming you also remove the brake master cylinder and booster):
Have an ample supply of disposable nitrile gloves, paper towels and brake fluid.
Have some pig-mat or other oil absorbent pads.
Put a plastic bag under the pig-mat as it may saturate and leak through.
Make sure you have a vacuum bleeder to evacuate the reservoirs and lines.
Make sure the tweaked clutch line doesn't touch the body or brake booster.
The new CMC outlet is 0.8" lower and maybe about 5 degrees different angle.
The clutch pedal feels about the same.
Since you have full access to the CMC, you don't need to remove the clutch line.
Just unscrew the line fitting from the connector fitting. Install a new connector
fitting in the new CMC (with new clip) before installing. This is just my recommendation.
You will have to do the line tweaking with one hand as it's very difficult to get both
hands in the cavity, even while laying on top of the engine. You should be able to
finish the whole project in one day, including bleeding the clutch line and brake lines.
You will go through several bottles of brake fluid when bleeding the brakes to get the
air out of the system. I went through almost 4 bottles of Redline RL-600 for the whole
job (clutch and brake system). https://www.redlineoil.com/rl-600
Also, the Redline MTL is a better trans fluid than stock.
https://www.redlineoil.com/mtl-75w80-gl-4-gear-oil
Between the non-damped CMC and the MTL fluid, the car shifts like a dream.
#107
Finally did the master install yesterday! Car shifts beautifully, I can actually spin going into second even with the stock clutch. I ended up replacing the whole line which made install much easier. Didn't take any brake components off. Just involved the stock master and snaked it out backwards. Strut did come out of course.
just need new fluid. Before I did this my third gear started popping out and 4th gear grinds a bit.
the third gear problem is pretty much gone 4th gear is better but still some grind. Going to change out the MTF fluid to a synchromesh fluid.
Disassembled the stock diaphragm and didn't notice anything out of the ordinary at least to me.
would recommend getting a new coupler and u clip to avoid dealing with the corroded stock pieces. That way you can have a ready to go unit that isn't depending on any parts from the old unit.
01-05 Civic master top stock is bottom.
#108
Brock
What clutch line is that? Also, the Redline MTL is better than GM Syncromesh fluid.
#109
Bastoche_R (12-28-2018)
#111
Transmission Pro
I would be concerned as to how the J-series engine would respond to not having a dampened flywheel. I would be careful that this isn't a flywheel that was designed for another Honda engine that might have the same fitment as J-series, but doesn't require the dampening. Something like the K20C comes to mind.
#112
Latent car nut
#113
Transmission Pro
Why? Because I just arbitrarily made the decision that it is.
And that is the same method that marketing uses for "performance" automotive parts. Because someone with no credentials said that it is.
The following 2 users liked this post by Bense:
Euro-R_Spec_TSX (02-03-2019),
horseshoez (01-31-2019)
#114
Latent car nut
I think the only "stage" some of us can claim with any authority is "Stage 0". Why? Because some of us have bone-stock cars.
#115
Transmission Pro
Side note. I just spent 2-3 minutes looking on the heeltoe website at the flywheels Marcus sells on there.
I love how overpriced this is.
https://www.heeltoeauto.com/clutch-f...j35-daily.html
I don't like aluminum flywheels because I don't like the way that the starter gear is fastened to the aluminum disc.
https://www.heeltoeauto.com/aasco-al...103212-11.html
Seems like there will be something offered from the new k20c (civic type R, accord sport 2.0t) that can work.
#116
Brock
I don't care for XLR8 parts. They don't appear to do real engineering when designing there products.
I don't care for aluminum flywheels either, but they are what's available. And AASCO is high quality and well designed.
I've had them machine a couple J-series flywheels for me and I like working with them. FYI, if anyone wants a very nice
clutch/flywheel setup for J-series consisting of a custom AASCO flywheel, Exedy pressure plate and custom high performance
organic disc, then contact me. A member on the forum has a kit that I designed and couldn't be happier with it.
I would really prefer a one-piece CNC machined chrome-moly flywheel like the OEM K20A flywheels on the Type-R engines.
I thought the K20C has a dual mass flywheel? Have you checked one out? Let me know because if you haven't, then I
might have to buy one and analyze it.
I don't object to the notion of a dual mass flywheel as it reduces shock to the drivetrain, but the OEM dual mass flywheels
are incredibly heavy. See my initial posts in this thread. They are around 30 lbs. The aluminum flywheels are around 15 lbs.
I think 15 lbs is too light for the vehicles the J-series are found in. I think 20 lbs would be the ideal weight. Also, the LuK
flywheels have a lot of slop between the masses. At least the J37 dual mass flywheel (made by Exedy) has tension on
the internal springs at all times.
#117
Are you sure you "love" how overpriced XLR8 stuff is?
#119
Brock
Because Bense got me curious about the K20C clutch setup...
The K20C in the Accord Sport has a dual mass flywheel, so I have no interest in it.
The K20C in the Civic Type-R has a single mass flywheel and it weighs 19 lbs.
The Type-R flywheel, pressure plate and disc are all made by Exedy. The disc has
a 240 mm OD, same as J-series discs, but the hub is larger diameter and can't be
used with any J-series pressure plates. This is likely due to having only 4 springs.
I prefer a disc with 6 springs as it tends to be more compact. The flywheel will bolt
up to a J-series crank as would be expected since the J-series and K-series share
the same bolt pattern. However, a 5 mm spacer would be needed to get the pilot
bearing at the correct distance. The pilot bearing ID is the same as a J-series, so
it's feasible that the flywheel and clutch setup could be used on a J-series.
Issue 1.
The starter gear on the Type-R flywheel is close to the engine, like the J32A3 and
J30 flywheels (older style clutch case). Also, I don't have a J32A3 flywheel laying
around, so I can't measure the distance from the crank mating surface to the top
of the starter gear.
Issue 2.
The starter gear on the Type-R flywheel has angled teeth, whereas the J-series
flywheels have straight cut teeth.
The short answer to flexer's question is NO. Even if it's determined to be possible
to use the Type-R flywheel and clutch setup on a J-series, it would only be for
the older style clutch case applications.
In order to use the Type-R flywheel and clutch setup on a J-series, the starter
gear would have to be at the correct height after bolting the flywheel onto the
crank with a 5 mm spacer first. Second, the gear on the J-series starter would
have to match the gear on the K20C starter. Although it's possible, it might be
wishful thinking that the K20C starter gear could be swapped onto a J-series starter.
Issue 1.
Issue 2.
#120
Brock
I got some measurements for a J32A3 flywheel and the height of the ring gear is 12 mm. So, with the requisite 5 mm spacer the height would be 17 mm.
The Type-R flywheel ring gear has a 14 mm height. Too much mismatch there, plus the J32A3 has a slightly smaller diameter ring gear. I think it's pointless
to investigate further.
