Xlr8 exhaust
STARLIT (09-14-2019)
Which exhaust is it? The dual or quad? If it's the dual, it's meant for a base TL. The quads are meant for the Type-S, so you would need to swap your rear bumper to fit the exhaust tips or get the A-Spec rear lip meant for the Type-S and cut your bumper to make some space for the tips.
As for checking out a used one, EvilVirus pretty much covered what you need to do.
EvilVirus (09-16-2019)
So even if I get the a spec rear lip I’ll still need to cut into the bumper?
Most likely. The Type-S exhaust tips are about 3" each, meaning a width of a little more than 6" total, so the rear bumper and rear A-Spec lip were made accordingly. As well as any aftermarket exhaust meant for the Type-S.
You can measure your base tips, but I doubt they will be close to 6".
If using the base bumper, you will need to measure and cut to fit quad exhaust like cprime explained. The rear type-s a-spec lip can be attach to the base bumper after the bumper has been cut to specs. You can also go with a type-s rear bumper (direct plug and play)......I have a brand new one for sale but you are probably not in Texas
nazTL
21
02-23-2010 11:12 PM
