Well guys, it's been a while but I'm back. With a ton of new mods.
For those that don't know, this is a 2006 Base 5AT.
Current Mods -
AEM 3.25 inch Cold Air Intake
Throttle Body Coolant Bypass
EGR Valve Bypass
J37 Throttle Body
J37 Intake Manifold
P2R J37 Throttle Body Spacer
P2R J37 Intake Manifold Spacer
P2R J37 TB Thermal Gasket x2
P2R J37 IM Thermal Gasket x1
RV6 Hi-Flow PreCats
ATLP V2 J-Pipe
JE Test Pipe
Vibrant 2.5 inch Inlet/Outlet Ultra Quiet Resonator
XLR8 Y-Pipe
Rear Mufflers Delete w/ XLR8 Single Tips
UR Lightweight Underdrive Crank Pulley
AEM Fuel/Ignition Controller
BoomSlang Adapter Harness
PowerStop Drilled/Slotted Front & Rear Rotors
Hawk HPS Brake Pads
BFGoodrich GForce Comp2 A/S Rubber
Pro-Tuned By JE Import Performance
Pending Mods:
Braille Lightweight Battery
Hayden Transmission Cooler
Weight Savings:
Hood Insulation Delete (2lbs)
Stock Airbox Removal Replaced w/ CAI (8lbs)
Weather Strip (above hood) Delete (2lbs)
Engine Bay Covers Delete (6lbs)
Spare Tire Delete (36lbs)
Rear Floor Mats (6lbs)
Rear Seat Delete (46lbs)
Interior Carpeting + Insulation (25lbs)
Door and Center Console Trim (10lbs)
Front Floor Mats (5lbs)
Glove Box Delete (9lbs)
Trunk Insulation Delete (23lbs)
Lighter Exhaust Parts (30lbs)
Lighter Intake Manifold (8lbs)
Side Air Bag Delete (10lbs)
Air Bag Trim Pieces (4lbs)
UR Lightweight Underdrive Crank Pulley (7lbs)
Headliner and Plastic Bracket Delete (6lbs)
Rear Door Panels (14lbs)
Center Console Delete (13lbs)
Rear Speaker +Rear Sub Delete (8lbs)
Rear Seat Belts Delete (6lbs)
Rear Speaker Cover Delete (5lbs)
Total savings - 289lbs
Made 240 at the wheels on DynaPack -
69-105 WOT pull on quarter tank of gas -
The car feels ALIVE!!!
Current Mods -
EGR Valve Bypass
J37 Throttle Body
J37 Intake Manifold
RV6 Hi-Flow PreCats
ATLP V2 J-Pipe
JE Test Pipe
XLR8 Y-Pipe
Hawk HPS Brake Pads
Pending Mods:
Weight Savings:
The following 2 users liked this post by OsK:
EvilVirus (04-27-2016),
TheTLProject (04-26-2016)
