Weight Reduction? The emaciated TL.
#82
Originally Posted by ACCURATEin
haha theres a 50/50 chance i might take it apart and see if i can slide it out the back door if i find the right angle. If i do that i'll go weigh it and if i deem it a substanial amount of weight i might just have to plug that hole up with something!
#85
Originally Posted by ThinJim
the moonroof on my 2nd gen cl weighs 30lbs, just weighed it, probably the same for the tl give or take a couple pounds.
...do you still have your CL?
#86
Originally Posted by mishar
I’ve measured it with tape measure and I know that metal is steel 0.5 mm tick. Result is 15 lbs.
I am not kidding about mid V8. It would be easier and cleaner mod than installing turbo on TL engine.
No need for a turbocharger really (that would be cool though), the OP already runs a supercharger and it can produce respectable power once proper fuel and ignition parameters are dialed in, which Hondata ECU reflash will take care of.
#87
Good info. It does look like it weighs a good amount.
Car will look better than this rendition someone on here made for me.
#88
yeah, two actually, one to get around in and the other a project. you'll like this thread, https://acurazine.com/forums/showthread.php?t=191803
I'm glad you're still tinkering with the CL's...i thought you were done with it when you sold the turbo from the silver one.
#89
#90
Oh that's truly awesome!
#91
I'd like to see what you make of the CL, are you going to do anything to lighten up the body?
#92
Originally Posted by ACTROS
Could you share you measurements then???
Volume is: 47.2 cubic inches or 750000 mm^3 = 0.75 l
Weight is: 47.2 cubic inches * 0.28 lb/cubic inch = 13.2 lb or 0.75 l * 7.8 kg/l = 5.8 kg
FWD is BS with 260 HP. With more power it just becomes bigger BS.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
