Weight Reduction? The emaciated TL.
#41
Originally Posted by KN_TL
Right, that was my point about the roll cage.
I just can't imagine that cutting up a monobody chassis and replacing it with CF can be as strong as the original structure. How would the CF be adhered to the existing steel that is as strong as a steel to steel weld? That is the part I don't understand.
I understand CF being used in the autos you mentioned, but they are designed with the use of CF in mind. Not an afterthought.
The strength of the TL chassis should not in any foreseeable way be weakened through the application of a CF roof versus the stock roof, I'm not sure, however if the stock roof is aluminum sheet metal or not, and dependent on what type of metal it is could tell us how much weight we'll be dropping from the highest point of the vehicle, which should enhance the handling properties of the car. Bear in mind this IS NOT the same type of carbon fiber that is used to pretty up the interior of our TLs, this will be Carbon Fiber reinforced with Kevlar, this is the same material used on the new Boeing 787. This high grade stuff with very long and complicated manufacturing process.
You guys are right about the installation it cannot be welded on, special riveting and adhessive will need to be applied, which we will seek through the manufacturer, they have done this type of work for many vehicles and they can make a mold for pretty much anything.
We will NOT be the first to pursue this kind of modification to a street car, as a matter of fact a carbon fiber roof has been produced for the Evolution and coincedentally the structure of the roof for the Evolution and the TL are the same.
Installing this would require the removal of the welds from the old roof, removal of the weather stripping on either side of the roof and removal of the winshield glass in both the front and rear of the TL.
#46
Originally Posted by Eoanou
If someone can find the service manual instructions on how to remove the roof, and the part number for the roof panel, that would be great. I need to give measurements.
I just checked the service manual and there's no reference to removing the roof.
#47
Well no matter, I'm going to remove the sun roof, the motor and all that and replace it with a panel, bondo it together, sand it down, paint, then CF vinyl, should be 30lbs of weight loss, and a lot cheaper, and I could use practically anything to replace the glass since the rest of the roof is reinforced to support a sunroof. I could lose more weight, probably 10lbs more, at least by doing the whole roof, but oh well.
Weird how you didn't find anything in the service manual, what happens if there is a hard dent to remove on the roof from a rock falling on the roof?
#48
There are several methods for doing what you mention without requiring an entire roof replacement. A person with a frame straightener, welder and all the other tools of the trade can do wonders.
I hope you're not taking my posts as negatives. Just curious and asking lots of questions.
Looking forward to what you all come up with.
#49
Maybe I'm just totally off the mark here. Are you talking about the entire roof or just the moonroof?
#50
94 DC4 RS LSV/Turbo
well the roof definitely comes off or else why would it have a part number of its own - 62100-SEP-A20ZZ
PS. did you remove the headliner (sunroof motor included) and everything else up there...? if so is it glued or is it held on with clips?
#52
Thanks for checking out what i've gone and done!
A CF roof might be complicated, and a little more than i'm capable of doing. Maybe extracting the sunroof components and filling in the rectangle with something. Right now i've got the headliner about to come out...just have to figure out how to take the dome lights apart.
#53
I've never seen individual parts for a unibody structure in the retail world. Maybe a bodyshop has access to them.
Of course not, I don't mind your questions at all, a CFP roof is quite a task. It requires removal of the welds of the original roof, removal of the winshields, removal of the over head carpeting, and who knows what kind of frame support is hidden under the roof that will make removal a hassle. Of course those would remain there but they would get in the way of removing the welds of he roof.
#54
Take pics, I need to know whats above the headliner, and I need to see the welds.
And actually I was thinking if a simple sunroof removal would worth it.
Stillhere do you know by any chance the measurements of the stock roof, lenghtxwidth? I could get a better estimate from the shop.
#55
You're probably right about the fumes, haven't really thought about that. There are some vents right beside the battery in the corner of the trunk though. I'm not sure what they're for but there are little flaps that open and close.
#57
#58
Originally Posted by leedogg
I believe those are for venting air when you close the trunk
#59
#60
Originally Posted by aznbo187
Get rid of all that sound deadening in the rear!
Btw, are you going to vent the battery fumes at all? It's going to be a bit safer especially since you have this wide open passage from the rear battery to the front cabin.
#61
Originally Posted by CleanCL
i dont know about braille... but typically those smaller batteries are dry cell... if the braille is not i would just ditch it for an odyssey, that's what i run and it's awesome.
Odyssey batteries are very good, a lot of corevette guys looking to ditch their OEM for a smaller replacement use these batteries, they weigh next to nothing. If they can power up a very high displacement V8, there certainly no problems for our V6.
#62
A sunroof CF plug would be a lot more feasible, and realistic to the TL crowd. Although I do love my sunroof.
I wouldn't want to make the plug out of CF it wouldn't look right, what I plan on doing is just plugging it with anything then putting a vinyl overlay, that looks like CF, and then brag about a CF roof.
#63
Roof Panel
Installation
1. Clamp the new roof panel, and measure the
passenger's compartment diagonally.
2. Check the body dimensions, door and windshield opening (see page 4-6), rear window and trunk lid
opening (see page 4-7). and check the width of the roof molding installation, then tack weld the clamped position.
3. Temporarily install the windshield, doors, and trunk lid, then check for differences in level and clearance.
4. Do the main welding.
. Weld the roof panel (A) to the outer panel (8) and
roof side rail (C).
. From inside the vehicle, weld the roof side rail
(D) and roof panel stiffener (E).
. Install the mounting bolts for the rear damper
stiffener (F).
. The roof area must be free of burrs and/or sharp
edges to prevent damage to the side cartain
airbag during deployment.
B __ /,15.5 mm {O.51 in.)
#65
Roof Panel Welds, Removal and Installation
Not much, but I hope this helps a bit! They don't provide any dimensions!
Roof Panel
Installation
roof side rail (C).
stiffener (F).
Roof Panel
Installation
roof side rail (C).
stiffener (F).
#68
Carbon fiber roof won’t be any lighter than original. It has to be at least 4 times ticker and material is not that much lighter. Original weights only 15 pounds, anyways.
If you really want to save some weight up there cut a piece of steel sheet metal 0.5 mm tick about 3” bigger than moon roof each way, shape it to the roof curvature, cut out moon roof with jug saw, take out all its mechanism and supports, glue and pop rivet your new steel roof and paint it.
If you really want to be radical go for mid engine setup. You don’t have rear seats anyways. Aluminum block V8 is not much heavier than TL’s V6, but can produce much much more power. 600 HP easily. No need to talk about weight distribution and handling.
#70
That CF roof idea is just way too much work and $$ IMO. If I was going custom anything, it would be a fat rear strut bar. This would probably feel just as good or even better.
Plus more ppl would probably buy this since costs won't be too high...
#72
Originally Posted by pohljm
Wow.........mid engine aluminum v8 w/ RWD, now your talking some serious modifications
#73
Thank you, now that I know that the stock roof only weighs 15lbs it would be frivilous to contruct a CF hood.
I will see what we can do as far as a moon roof plug is concerned.
#74
How the hell do you know that that roof panel weighs only 15lbs? What you've taken it apart and weighed it?
You gotta be realistic man, mid V8, you're kidding right???
Now the removal of a sunroof with all it's guts is a good idea and won't be costing nearly as much as cf roof!
I would really concentrate on removing the weight up front now, the rear is light as is!
#76
So i just got done taking the headliner out and it looks pretty neat now that everything up top is exposed. I can see the sunroof contraption and how its bolted to the frame. From what i can tell a CF roof might be a little bit too involved. The removal of the sunroof assembly is something to consider.
#77
Any chance you can see how much the sun roof components weigh?
#78
#79
haha theres a 50/50 chance i might take it apart and see if i can slide it out the back door if i find the right angle. If i do that i'll go weigh it and if i deem it a substanial amount of weight i might just have to plug that hole up with something!
#80
I am not kidding about mid V8. It would be easier and cleaner mod than installing turbo on TL engine.
