Unhappy about 1/4 time!!!
#161
All motor
F the check valve. I wonder if it really does help ET/trap.
#162
ReDevil
Clutch Slave Check Valve? Bare with me here lol; I have auto 3gTL, but daily 6mt Tsx. I just did the SS clutch line to replace the rubber bit. That made a noticeable improvement on the clutch feel. I hammer on the car time to time, and doing quick row through the gears its def noticeable how much quicker it engages, I feel like it would knock a solid .1 off Et on 1/4mile. That being said, the slave check valve has the same tendencies, of play in clutch engagement. I think if you did both 'mods' it would def help. I did order a spare slave for my tsx planning on doing the mod, but its an entirely different unit(than the TL), going to see what interchanges, that has the 'easily' modded design.
Sonnick (11-19-2012)
#164
Doubtful, but it does make it more satisfying to drive; the thing really numbs clutch engagement. After watching your latest vids though, you look like you're having some issues with third. Have you switched to GM Syncromesh fluid? I'll tell ya', switch to it and you'll never miss third again! Do both mods actually. Less than $50 and you'll love it.
Sonnick (11-20-2012)
#165
All motor
Yea I did switch, but I only drained/refilled once, and that was easily 20K ago. I heard it's better to do it 3x. I should probably do it again....I'm not gonna blame the fluid for my missing 3rd though, maybe partly. But I'm responsible as well
#166
I might switch back to gm syncromesh, I have had some noctchiness and hard shifts on cold mornings but i am working on my electronic cutout right now! The flange should be here tomorrow and ill get that welded in. this is the cut out i am planning on going with......
www.dmhperformance.com/ecutout.htm
#169
Bird is the Word
Let me know the next time you guys make it out to Bradenton. I went last night and hit a 14.85 @ 94.xx my first run out. It was cold out and the track was empty. My check engine light came on so I called it quits after my 4th run. It was my first time out in about 10 years and had a blast. Would be nice to race some other TL's.
