Type-S Brembo Brakes on Base 08 TL
I am currently installing the Type-S Brembo Brakes on to my Base Auto 08 TL. This is a how to...
Step 1: Purchase Auto,M/T Type-S or 04-06 M/T Knuckles/Spindles (All these models have the same wheel bearing, ball joint and axles as the Base 07-08 Auto) Step 2: Purchase Brembo Calipers, Type-S Pads + Rotors + Brake Lines (The Base Model brake lines will not fit the Type-S Calipers) Step 3: Swap current parts list onto your vehicle, ensure to lubricate the pads and slider pins, bleed brakes properly, replace any torn bushings, check ball joints for play, etc... Step 4: Hope the 07-08 Base Model Wheels clear the Type-S calipers as I haven’t gotten there just yet! Hopefully this helps anyone looking to do the swap if you have any questions feel free to ask me, and if anyone knows if the 07-08 Base wheels clear the 4 piston calipers that would be great! Thanks! |
07-08 base TL wheel will clear Brembo caliper.
Originally Posted by Scott Salt
(Post 16449306)
(Post 16449306)
Old thread revival :zombie:
For anyone wondering, the 07/08 base wheels barely clear the Brembo calipers when cold. I don't know if the calipers expand too much when hot to be an issue. |
