Turbo 6MT - J32A to J37 Cam & Crank sensor upgrade parts list
Howdy Acurazine. I am in the process of building my wife's 04 6MT and I am using an AEM Infinity series 7 to control the engine, and I would like to get the EMS up and running N/A to eliminate any tech issues before the turbo goes on. The stock J32A3 has a 12 tooth crank trigger wheel and I need to upgrade to the J37 type 24 tooth wheel setup. I am trying to compile a list of the needed parts, I just don't have access to a J37, but does anyone have an FSM or diagram of the J37 engine sensor layout, or any side by side pics of the timing side to compare?
not that it matters but here is the basic setup- Stock J32A3 Longblock Custom turbo kit with 6062 Billet T4 A/W IC 3.5" hood exit cutout/3" back to stock mufflers 44mm gate Custom Big Boy Intake maifold w/ LS6 DBW TB surge tank w/ Walbro 450 FIC 1100cc Injectors S2K Coils AEM Infinity & Racecapture2 |
Curious as to why not just buy an '08 TL-S ECU and a Hondata. Seems like it'd be much easier than dicking around with a full standalone system.
Also, are you building this motor? Or what's the point of the J37 crank? |
A Turbo TL? I’m in! |
Originally Posted by mdnborg
(Post 16345473)
Also, are you building this motor? Or what's the point of the J37 crank? The current motor is not built, should make 450-500 pretty easy, but it is temporary to get the fitment correct on the cast manifold heads. Once testing is done and any issues ironed out, I will switch to the multi port heads and a mild block build. Im honestly not even worried about the motor, it's keeping the trans alive that is the key. There is no J37 crank involved, just the crank sensor/wheel and cam sensor are upgraded. The J37 uses higher resolution hall sensors that allow much tighter ignition control vs the older mag/vr type. |
A TL with a hood exit; I've long wondered what that would look like
You may have better luck in the 4G group. Or if you have FB, there's a page called J series engine nation. I'm sure you could find your answer there. GL |
Lmao Turbo guy. How far along are you in this plan? |
I will have to check out that facebook page, just hard to find a knowledgeable J specific site since that old one shut down. So far on the build I have most of the hard parts to get the majority fabrication done, and I have the ECU and short harness. Stuff fabricated so far - A/W IC is mounted, turbo is mounted, A/W tank, surge tank, intake manifold, airbox, battery relocation and strut bar which will also have the up pipe mount. I am out of argon so some finish welding is still to be done. Next on the list is picking up a spare motor to build the manifold on and freshen up to drop in with the turbo, as I am building while keeping the car drivable, so some things have to wait. Shooting for boost in mid spring. The goal of this current build is a daily driveable 450-500whp that is as reliable as a stock TL, and none of the drawbacks of the other Turbo/SC/N/A options for the J. Once that goal is met, someone should have a dog cut gearset by then and then :turd: gets real. I'm not quite ready to share pics of the setup but I can show what it was N/A and some of my other builds.
https://cimg0.ibsrv.net/gimg/acurazi...cb28d77043.jpg J32 J pipes and 3" Exhaust https://cimg1.ibsrv.net/gimg/acurazi...d3dae207ba.jpg https://cimg7.ibsrv.net/gimg/acurazi...e451927675.jpg https://cimg8.ibsrv.net/gimg/acurazi...973617debb.jpg https://cimg0.ibsrv.net/gimg/acurazi...1417b8d966.jpg https://cimg2.ibsrv.net/gimg/acurazi...e1ba1e3b30.jpg https://cimg3.ibsrv.net/gimg/acurazi...c6ebc39b4b.jpg https://cimg4.ibsrv.net/gimg/acurazi...4752f8d770.jpg https://cimg6.ibsrv.net/gimg/acurazi...e3199e12a4.jpg |
I’m looking forward to this! The other builds look sexy |
500whp reliably? |
Originally Posted by Saving4aTL
(Post 16346230)
500whp reliably? I scored and found nice stash of stainless in the shop, so I can start back on fab when gas gets here. https://cimg6.ibsrv.net/gimg/acurazi...bc8cc65635.jpg |
Wow! Nice builds! This will be Nice to see! In for progress and pics! |
sub'd
Looks like a fun project! |
I got gas filled and should be ticking away at the charge piping and up pipe over the next few weeks as time allows. Random update I guess lol.
Your avatar is sexy. |
