tl 08
please if somebody wants to help me email me jc03_ge30@hotmail.com.
I want to modify my tl
Welcome to the forums.
I moved this thread to Performance Parts and Modifications, and also deleted the two posts you made in other threads.
I know you're anxious to get started, but this will get more attention than posts in other peoples threads.
You can also check out other threads and do a search on any particular parts you are interested in.
There is no way to flash the ECU to get the limiter removed, but Touge on the RL forums got past his 130MPH limiter using the APEXI RSM. Also 220KMH is very fast, past those speeds on the stock tires are unsafe, get yourself a better set so you don't kill yourself when you have a blowout. Also I don't condone driving so fast, it's dangerous.
AZ Community Team
Received 7,771 Likes
Have a look at this thread:
https://acurazine.com/forums/showthread.php?t=180003
Also try the SEARCH feature for "APEXI". There is also some kind of Piggy-Back system from AEM. However, I don't think either one will remove the speed limiter.
Up to now no one has been able to hack the ECu in the TL.
Originally Posted by ACURACANCUN
Perfect, Somebody Else? I Want To Modify Everything Can Help Me For Better Response And High Speed
Comptech supercharger +60 HP
ATLP exhaust +10 HP
Port and polish +2-3 HP
Weight reduction
Suspension modifications (tein SS setup)
ATLP J-pipe
ATLP test pipe
Pre-cat deletes
and anything else you can afford.
Originally Posted by csmeance
Do all the modifications that are available for the TL:
ATLP exhaust +10 HP
Weight reduction
ATLP J-pipe
ATLP test pipe
Pre-cat deletes
ATLP exhaust +10 HP
Weight reduction
ATLP J-pipe
ATLP test pipe
Pre-cat deletes
There is way too much info to just give away, I suggest you search for it.
