Supercharger installed and no gain
Old 11-01-2006, 07:57 PM
  #41
8 second & 150 mph member
RYAN97812's Avatar
bernard you made 341 to the wheels, what kind of dyno was that on? Roller or hub mount? Never had a problem with the seven regulators that i have crushed on all the kits i have installed. Comptech redesigned the tool to crush the regulator and it crushes the other side then the original tool but both worked and were fool proof. You must have really tightened the tool in a vise pretty hard to overcrush it. Are you just using a g tech meter or do you have a real track by you that you run at? Bone stock i ran 14.72 and with the s/c and cat back it went 13.66 no other mods then that.
Old 11-01-2006, 09:07 PM
  #42
5th Gear
mrobichau's Avatar
Nav Mod? new image? how?
Originally Posted by ayethetiense
didn't anyone tell you that the SC only works in the US? hahaha
hope you figure out whats wrong with it. good luck!
how did you mod nav image?
Old 11-13-2006, 09:20 PM
  #43
RobertQ's Avatar
Originally Posted by Bernard1973
The car is even slower than before, I have raced with my friend who owns manual TL, and his Tl has no S/C, result I was smoked totally
The AFR is about 10,5:1 which seems to be to rich.
Everybody from service where I installed is wondering why,
I notice a big whistle but the car does not accelerate,
on GTECH I had no chance to go under 7 seconds and undere 15,5 quarter mile !!! before I had arround 14,1
No positive answer from comptech, so only hope from You boosted TL drivers
Bernard
SAME SHIT HERE ALL THAT MONEY FOR NOTHING
Old 11-13-2006, 09:34 PM
  #44
Former Sponsor
Excelerate's Avatar
look like we both with mario_bbb solved the damn problem,
the FPR has to be sqeezed/ pushed very accurate, the device Comptech provides is shit worth nothing, we have bought with mario_bbb 5 FPRs and tried to reach exact amount of fuel pressure Comptech claims, with correct AFR and boost
So we have our best results with 0,4mm gap between two parts of CT device, we dynoed the cars many times with various numbers 290hp, 320hp, 330hp, and finally we got 341hp under the hood,
now the play starts ... LIFE TO SHORT TO BE SLOW !!!
See You on SEMA if anybody comes, phone me at (860) 9655615 from 1st after 1120PM
Old 11-13-2006, 10:39 PM
  #45
RYAN97812's Avatar
I dont understand how people are getting this wrong?
Old 11-14-2006, 03:11 AM
  #46
Bernard1973's Avatar
we used as far as I remember five FPRs with different squeeze gaps, every time we did so we dynoed the car (all tests has been made on 6MT) and as I said the best squeeze gap is 0,4mm, every 0,02 makes a difference - it's weird but it's tru, notice 0,38mm has 10hp less than 0,4, the HP we got are not on wheels, that is under the hood, whp are more a less same like CT says.
We use two different dynos (MAHA largest german manufacturer up to 500whp, and custom made polish 4x4 up to 1200whp where we dynoed our 4x4 corvette with over 1000whp and 9seconds to 402m(1/4mile)
Second TL 5AT has little worse results, but its engine was just less powered when it left the plant, before S/C 250hp instead of 270 and the result is 320hp
Old 11-14-2006, 03:13 AM
  #47
forgot to write AFR at WOT it's 12:1, the boost at low rpms is approx 3,5 and at high revs reaches 4,5
Old 11-14-2006, 03:19 AM
  #48
B A N N E D
lookinco's Avatar
SO the dyno numbers are not WHP?
Old 11-15-2006, 01:22 AM
  #49
how could You reach 340whp from a V6 ?stupid questions
Old 11-15-2006, 02:05 AM
  #50
B A N N E D
lookinco's Avatar
340whp with a V6? A turbo CL-S running at 10psi dyoned at 460whp, and that's with stock internals i believe.
with the new TypeS motor and supercharger running at 8~10psi, i am expecting myself to have at least 350whp.
Old 11-15-2006, 05:40 AM
  #51
that's possible, we have over 600whp Jazz/FIt and same number Integras, but not with supoercharger from Comptech, that's what I ment writing stupid question with stock engine and S/C, sorry for misunderstanding
Old 11-15-2006, 06:24 AM
  #52
B A N N E D
lookinco's Avatar
if my memory is correct, i beleive a fellow member on this forum dynoed at 320whp with the comptech supercharger running at only 4.5psi. That's with stock engine and just bolt ons. With the high boost pulley I am sure we could get it close to 350whp. I don't see any reason why the comptech supercharger is not able to do this. The eaton charger is able to run up to 10 ~ 15 psi provided there is adaquate cooling and good fuel tuning.
I believe even up to 400whp is possible with the comptech supercharger as long as there is good intercooling and fuel tuning. And with the comptech supercharger running at stock configuration, many TL have dynoed over 300whp.
Old 11-16-2006, 02:13 PM
  #53
'06 750Li Sapphire/Creme
ndabunka's Avatar
The 320 is NOT fwhp, it's "at the crank" and yes, 320 "crank" HP (up from 270HP) is fairly common with the s/c as it typically addes 50-60HP
Old 11-16-2006, 03:19 PM
  #54
B A N N E D
lookinco's Avatar
LOL maybe you should do more research before you post false information like that. One of the member ,Nitrotiger, dynoed at 317WHP with supercharger, E-shift procat, Comptech exhaust, and boost cooler. Check out his thread and dyno sheet here: https://acurazine.com/forums/showthr...highlight=dyno
There are other members that dynoed at well over 300whp. These are NOT crank HP.
Also like you stated if TL is only making 320hp at the crank with the SC, with 15 to 20%drive train lost, we would only be at around 250 to 270whp which appearantely is not true unless there is something seriously wrong with the TL.
Old 11-16-2006, 04:27 PM
  #55
ndabunka's Avatar
LOLEL - You seem to contradict yourself. Read the post I was replying too. It stated ONLY S/C, no cat-back, no etc. Your post to me is in error, not mine. No offense however. Also, the drivetrain loss is different for the manual and AT's. It may not be as large as 50HP but in #'s vary. Most AT TL's have around 210rwhp from the factory. I guess the manuals have up to 220 so my statement that an Supercharger ALNONE cannot get ANY TL from the 210/220 range into the 320 range will stand. As far as claims by others... This IS the internet and people often do not understand what they are talking about. Like you I have seen a number of IDIOTS on this forum claim 300fwhp only to have to run back with their tails between their legs when the obvious is pointed out. So beit. I am not in anyway saying that 300+ whp is not possible. WHat I am saying is that 300+ wheel horse power (i.e. as measured AT THE GROUND where the wheels meet the ground) is NOT POSSIBLE with a supercharger ONLY. Re-read and I think you will agree.
Old 11-16-2006, 04:42 PM
  #56
ndabunka's Avatar
Mayeb I am in error. He did reference... Just "bolt ons"... Let see... The S/C adds roughly 60HP. The cats add what 15? the CAI another 5-8. The pulley can do (just about anything), the mapping of the fuel system, NOS, radial drags... yea, I guess you can call ANYTHING a bolt-on so, yea... 300+HP with just bolt ons is possible. Of course, ANYTHING can be bolted onto a TL EVEN a 900HP v8 could "theoritically" be "bolted on... Where does it end?
Old 11-16-2006, 05:16 PM
  #57
B A N N E D
lookinco's Avatar
I never mention ANYTHING about getting over 300whp with ONLY the stock engine and supercharger. 317whp is for the supercharger with simple bolt on. No NOS and definitely no V8 engine..lol
check out another member's dyno. He dynoed at 309whp with ONLY the supercharger and comptech exhaust. Nothing else. There are the dyno graph and video to proof. All dynos are showing WHP numbers (i.e. as measured AT THE GROUND where the wheels meet the ground). I don't think anyone took their engine out to dyno the crank HP.
All I am trying to say is that the TL with supercharger is capable of making those power and not as weak as you guys thought. Shouldn't you be happy about making more power IF you actually own a TL?
And if your biggest argument to other's prove is "This IS the internet and people often do not understand what they are talking about", then you are right! "Where does it end?"
Old 11-16-2006, 05:21 PM
  #58
ndabunka's Avatar
Common quotes from the thread you pointed me to above..." Stock HP is 220-230. The latter being for a 6MT"...." With the s/c I gained 21 whp and 16 lbs/ft from the Procats"... "with the s/c kit it showed 287whp on the dyno back in June"...Sure seems like the guys getting 287whp is not getting anything near the guy gettign 314whp. If 220-230 is stock whp and it only added 21whp, the number SHOULD be more around 251whp (like I stated). It also sounds like (as with ANY forced induction effort) that you can get differing success rates and therefore more or less power fomr the s/c "bolt-on". Seems like 60whp is about the max based on most threads so 230+60 yeilds 290...not 300+
Old 11-16-2006, 05:30 PM
  #59
B A N N E D
lookinco's Avatar
hmm.....if according to your post, a TL with procat have around 251whp and the supercharger adds 60whp, then shouldn't it go up to 311whp?
And if you actually know anything about tuning, you would know numbers do not add up like that when you put mods on the engine.
Old 11-16-2006, 05:32 PM
  #60
ndabunka's Avatar
Unfortunately, all dynos do not list HP the same way. For example, the Mustang and Dynojets often differ by over 10%. The setup of the dyno is also critical. I can setup a dyno showing that I have an auto. The dyno then can apply a different loss ratio to the tranny then in a straight drive. If the next guy has a manual and uses the same loss figures, the reading go way high (like has happened in a number of these report you see). Face it, most guys want to claim they have the "strongest engine". Maybe it's a sign of insecurity. I personally, would rather see an accurate reading. I took my TL into a shop that had a Mustang unit and had it dyno'd. Unfortunately, they were only familiar with dynoing 4wd cars and therefore left it on 4wd when dynoing mine. Mine showed 186whp max (which I know is wrong) but the price was cheap and they didn't know how to fix it at the time so I just let it go. I do out run most other TL's even though mine is an AT with no mods. Figure I either (1) have better wheels (most likely) or (2) drive better (less likely) or (3) Have a hot engine (mid-likely) so... now that it's about paid off, it's probably time to try the SC...Glad to see some are having (or at least reporting) significant success.
Old 11-16-2006, 05:35 PM
  #61
ndabunka's Avatar
Hey, those weren't MY words.. they came form the other posters on that thread. I agree that it is not always a striaght line model. I also agree that with s/c and cats and pulleys etc 300+ is possible so we really are on the same page. SC alone = no 300
Old 11-16-2006, 05:39 PM
  #62
B A N N E D
lookinco's Avatar
Also, there are many reason why some TL didn't dyno as high as others. The main problem is we have no tuning options and we are only relying on the ACM from comptech and a crushed FPR. This alone will affect how much fuel is going to the engine which obviously would affect how much power the engine will make. Also, no two engine is identical. Some will always be stronger and some will be weaker.
All i am doing is showing that the TL is capable of making those power. There's no point arguing by quoting the TLs that dynoed low numbers and claim the ones making high number are making things up.
Old 11-16-2006, 06:36 PM
  #63
RYAN97812's Avatar
You want true hp your NOT going to get it from a dyno. You can base hp by vehicle weight and trap speed (mph) and figure out closer to what your real wheel hp is than a calculated dyno program. A dyno is a great tuning tool if the SAME dyno is used each time in roughly the same conditions. All the bickering over hp is a waste of time. Track it with out a s/c (which i did bone stock 14.7 @ 96 mph which equates to 247 fwhp) and then track it after your mods and youll see what kind of numbers you make (s/c and cat back thats it 13.6 @ 102 which equates to 298 fwhp) So throw whatever numbers you want around or argue any point you would like but try power is easily measured at the track and not by a g tech meter or a dyno. Et isnt useful for figureing hp since it is affected by wheel spin but mph hardly is.
ArcticDuk
06-29-2016 06:57 AM
BoricuaTL
04-08-2016 01:08 PM
obert
11-07-2015 07:32 PM
TxRzrBk
09-17-2015 01:07 PM
mgbe11
1/2G MDX (2001-2013)
09-15-2015 07:53 PM
Quick Reply: Supercharger installed and no gain
