Strange sound after throttle body spacer installed.
So last weekend after I installed the throttle body spacer weird whistling sound started to come out of the intake at about 2000-3000 rpm while driving... anyone know what could it be?
I'm assuming that you have an aftermarket cold air intake. Did the sound occur at all before the TBS install? CAI are known to whistle. Try taking off the intake and putting it back on the spacer to see if that solves the problem. Could be an air leak.
Did you plug the hole in the spacer (it comes with a small plastic npt thread plug)? It's for an alternate vacuum line or some such thing - I really don't recall for sure what it's for.
If so, are you sure it's tight? Did you put any teflon tape on the threads? If not, you should put a plug in there. :tomato: Edit, btw, it's typical. Lots of people have reported a whistle. |
what is the purpose of this spacer?
Originally Posted by Vigor66
(Post 12859562)
Originally Posted by Bearcat94
(Post 12859563)
(Post 12859563)
I have an AEM CAI and the p2r tbs on my car, and I've had the whistle since the install. I actually like it though. My father has an 03' Cobra with a CAI, and after he put his Accufab throttle body on, he got the same "whoosh" sound, only much louder :rofl: |
Originally Posted by killersrt
(Post 12859600)
Originally Posted by vladkarnafel
(Post 12859596)
Definitely installed it, and tightened it all the way without any tape. I also have one thermal gasket closer to the throttle body side, should i install second one to the intake side?
Originally Posted by mau108
(Post 12859573)
It looks nice. ?? Not much beyond that. Might save a couple HP from heat soak. Maybe. |
(Post 12859610)
You should have one thermal gasket on each side of the TB Spacer (2 total).
(Post 12859613)
It looks nice. ??
The sound your hearing is an air leak, probably at the plug on the spacer. I put medical tape on mine before I installed it an didn't have any problems. Or course I got rid of the spacer after I dynoed the car and saw that I had lost 5 HP to the wheels, and that was with the spacer and the thermal gaskets. If your looking to reduce the heat a bit, I'd eliminate the spacer and do the throttlebody coolant bypass mod. That thermotech reflective wrap stuff for the CAI works well too. I think the part # is 14500. Also, for the leaks, check the bolt in the CAI to make sure that is tight and sealing. They leak air there too. I actually used some Honda bond on mine to quiet it down. Check the union piece to ensure its on properly as it is a bit tough to get that back over the intake tube after you install the spacer. Make sure the clamps are tight both there, and at the filter. Should be fine after that
Also consider sealing the gaskets with a copper sealant. See here: https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/another-p2r-tb-spacer-install-807329/
Originally Posted by Dave_W
(Post 12859731)
(Post 12861939)
I gotta take everything apart this weekend and make sure everything is sealed off.. So you actually lost 5hp with spacer on??
Every dyno run should, ideally, say, "xxx WHP, +- yy". |
I was thinking of getting one are they worth it?
(Post 12861939)
Originally Posted by dinks07
(Post 12862910)
(Post 12862995)
No, save your money for exhaust work, or some other mod.
i get the whistle but i have no spacer just aem cai....what could that be, i had a stage 1 exhaust done didnt know if maybe theres a hole where they would have welded maybe?
it wistle because of that spacer.... can't believe you got it.. you would have been better off with the thermo gaskets..
Originally Posted by akertulis
(Post 12863638)
that's the sound of 30HP you got from that mod :thumbsup:
Originally Posted by myron
(Post 12864828)
