Stock or lightweight pulley w/SC?
I'm going to get a supercharger soon and have a question.
should i use the stock crank pulley or should i get the UR stock diameter pulley?
i heard that i shouldn't use the underdrive pulley with the SC
any suggestions?
any suggestions?
The issue with running the under drive pulley is that it's under driving the supercharger as well as the rest of the accessories, meaning that it's not producing full boost. IMHO, the only reason to run the under drive pulley is to reduce the parasitic loss that the accessories create. With the supercharger installed, you're not even going to notice the minuscule difference anyway. Just get the stardard size pulley.
takin care of Business in
Received 4,732 Likes
stock sized, light weight !!!
Chapter Leader (NY/NJ)
AT or MT? if MT and plan on installing a lwfw then stay with stock pulley since the common practice is either LW pulley OR LWFW. the flywheel will yield more weight loss.
The issue with running both is that you lose any sort of dampening on the crank and will likely develop some some nasty vibrations in the motor. That is unless you're going to have the entire rotating assembly balanced.
I actually sold my ltw crank pulley once I got my new clutch setup.
veggiemonster (11-16-2011)
2008, acura, cl, lghtweight, light, lightweight, pulley, pully, review, stock, supercharger, tl, underdrive, vs, weight
