Still looking for the "right" sound.......
OK. I removed my rez. and the mid muffler. But it's a little raspy. Also the low end (rumble) isn't there. So I was thinking of a magnaflow rez. Into a "Y" pipe to a chambered muffler. Then duel (2.5inch) out to the stock tip's. However I don't seem to find a free flow chambered STAINLESS muffler. Is the no such muffler? Please let me know what you think. I would like to hear the low end (rumble) of my TL.
Couple questions. Are you looking for one or two mufflers? I assume two but the way your worded the sentance made it seem like you wanted a resonator to the y into a muffler. i would suggest starting out by just adding in a magnaflow resonator, or are you wanting to change the entire setup?
Yes, change the whole thing. I am still using the stock rear mufflers (now). I will remove them. Then use a magnaflow rez. to a (this is the question) muffler. The thing is the chambered mufflers give you move low end rumble. But I didn't find one that was free flow and made from SS.
Magnaflow makes a chambered SS muffler, just not in the polished finish. Flowmaster makes chambered mufflers (obviously) though I wouldnt use anything but the 60 series. I cant remember if they are offered in a polished look as well...I seem to remember that if you swap the first number in the part number to an 8 that would give you that option.
Originally Posted by TLdriver022
just run straight pipes out the side!!
