Stage 3 Exhaust with different Dynomax Models
#42
I currently have a stage 1 (MM delete) and gonna get the XLR8 V2 J Pipe (which deletes 3rd CAT). Others have said that it has a nice tone to it. So id suggest this before doing too much and blowing money.
#44
Soooo I'm a newwwbb as you can see ..
06 25000 miles Pearl white navi![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
But what do guys think about mid muffler and 3rd cat delete??
Or even putting a hi flow cat instead???
I came from Lexus's which are notorious for their deep exhaust note.
These engines seem to be more "race car" sounding which is great but I need the deep twist..
#47
^ Not sure how it will sound but this is the setup im gonna do. I already have MM delete and Im gonna get a XLR8 V2 jpipe that deletes 3rd cat.
#48
So in theory
Mid muffler delete will give the good sound
And the cat delete will give me a lil extra power plus change the tone
Unless I go with a high flow cat
Ugh so frustrating because I don't wanna have a muffler guy go under the car again to do the cat replacement or whatever I decide to do lol
#50
I dont think you will gain a whole lot performance wise maybe 1-3hp by removing the 3rd cat. If you get a J pipe then ull def gain. If you keep the factory resonator I think u will have no rasp. I hate raspy sounding exhaust and that is the setup im gonna go. I havent really heard any sound clips on this setup so its really hard to tell.
#53
Registered Member
If you're going to delete the cat, just buy a j-pipe. Go into my progress thread and listen to my exhaust. I have the RV6 V3 (deletes 3rd cat), MM delete, and the Dynomax 24235 resonator. I have zero rasp and it sounds great.
If you delete the cat and remove the mid muffler you won't get any rasp because the stock resonator is pretty big and will deaden any chance of it.
zachlone (01-31-2013)
#54
^ His car sounds good in my opinion.
#56
I got the 24235 because I wasn't looking for a coffee-can, or ricey sound. I figured if I started from the bottom of the staged exhausts, and worked my way up, I could find out what I liked and didn't like progressively, instead of jumping the gun and not knowing how many steps to back track to get the sound I wanted. I do plan on getting the 24234 instead of the 24215 because of the OE pipe diameter matches the diameter of the race-bullet muffler.
#57
#58
Hey yall been lurkin in these stage 3 threads for awhile. After countless hours of reading and youtube watching, I pulled the trigger and bought the 24235. I currently have the stage 2 with the less commonly used magnaflow 10426. My car has a nice rumble upon start up, but then fades quickly. I also get that g35 sound from 1200-2700rpm. Anyways....
For the guys that have the dynomax 24235, do you think this resonator will enhance my current sound? I like how my setup is subtle yet present. I dont want to loose the luxury feel of the car, but I want a tad more sound. Any and all comments welcomed. Thanks.
#59
tweeder82o (04-05-2013)
#60
Thanks for the feedback zachlone. So you skipped the stage 2 all together?
My question now is since both resonators are the same size will I even hear a change? Are the internals what make the difference? Sorry for rambling, I just dont want to come to the conclusion that I bought a cheaper version of what I already have.
#61
#62
Sorry for the mini thread jack but if anyone is looking to get rid of their 10426 to try a dyno max, I'm looking for a 10426! Please PM me for any details, sorry again for the thread jack
#63
Alright, so after doing much research I've decided to go with the stage 3 mod on my 08 TL Type S. From what I've read, it seems that the Dynomax 24215 is deeper and better sounding than the 24235 if you don't plan on putting in a J-pipe. What I was wondering was if the 24215 would fit the TL type s, since I have only seen them on base TL's. Thanks.
#65
First sorry to revived an old thread but I ordered a dynomax resonator used of ebay the description was listed as 24235, I just got the package and there was the original invoice and it's a 24234. El Ban said that 24234 it's a 12 inch body but it's really not the actual size it's 18. I even found a video of the actual seller of resonator in YouTube and was wondering if you guy running the 24235 can tell me how much difference it's the sound vs the 24235, the link its below.
#68
24235 is an 18" case length, so if you are indeed set on a 12" model, you would not choose this one. 24315 is not a valid model #. If you are instead referring to the 24215, that is a 12" case. Both fit just fine, but the 24215 has 2.5" in/out so if you retain stock piping (2.25"), there will be more weld material to close the gap left by the two different diameters.
#69
04TLnick (04-07-2014)
#73
34 is a 12" case, and the 35 is a 18" case. Less resonating area = louder. If you add a jpipe that deletes the 3rd cat and have a 12" resonator with MM delete, you'll probably get some rasp. After going with the magnaflow rears, I'm less of a fan of the staged 2 or 3 exhaust sounds. But you'll have to try the 34 and see if you like it.
juanjh11 (04-09-2014)
#74
add magnaflow 11365 rears and delete the resonator altogether! aint nobody got time fo dat!
#75
Road Racer / Solo Addict
Bringing this back..
Have any of you done a stage 3 and then removed the third cat?
#76
Resonators aren't for how the car sounds when you rev its balls off in your driveway. Its for mid tones. Usually between 3-5K rpm. It allows those tones to escape so when you're in 2nd or 3rd and you roll onto your throttle you get a nice resounding burble.
Sounds tuned not loud.
#77
Just posted some high-quality audio samples of my '07 Base TL with the Stage 3 exhaust mod. Includes start-up, cruising, and WOT
https://soundcloud.com/rogersieber/a...xhaust-samples
EL BAN (08-25-2014)
#78
Still have this setup and love it, but have been thinking about removing the third cat..
#80
I know many have deleted the third cat using the J-Pipe..
Should have added that detail, I meant removing the cat with a test pipe..
So its a Stage 3 using the Dynomax 24215 and then adding a Test Pipe to delete the third cat, still using stock J-Pipe..
