Short RAM for 06 TL
I do. Check this out and let me know what you think.
http://i483.photobucket.com/albums/r...e/DSC00340.jpg
K&N makes one where it can be a short ram, and then with the supplied pipe it can be a CAI. Honestly a short ram won't help you, but hurt performance since it's sucking in hot air. It'd be easier just to remove the resonator in the intake track.
SwaxStar33
I had an Injen short RAM on my 02 TLS and it def. made a difference...I'm not trying to get crazy gains, just enough to help in my 06's sluggish RPM range.
2005 NBP TL 5AT w/ NAV
P.S. I also noticed a decrease in throttle response time which was great. I'm not sure about the extra performance. I certainly didn't lose anything.
Loving my 08 TLS!
I was looking at getting one of these as well since I have heard of people sucking in water when going over puddles...and I don't feel like spending the extra cash on getting a sheild or whatever in addition to a cai
SwaxStar33
Still a Noob!
Here you go. This is where I got mine from. Been on the car all year and no issues at all.
http://www.racinglab.com/weapon-r-in...ra-tl-018.html
Same as 05.
SwaxStar33
Same as 05.
Same as 05.
Much Appreciated!
As it's already been stated, why would you blow $200 for something that's going to lose hp? It makes no sense. Maybe I should start selling a throttle stop for the gas pedal for only $50 that would accomplish the same thing.
Loving my 08 TLS!
I didn't feel any decrease in the summer or winter. All I heard is VROOOMM..............VTEC Power!! I don't care what ppl say about losing hp. You can show me the numbers, but honestly I don't really care. This is not a race car, my daily / weekend car. Come to think of it, today is a nice day in NYC, I gonna go for a drive now.
I have the weapon R intake and it sounds good, and pulls harder (6sp) but some of you guys saying that youll lose HP, does that make sense?? The dyno shows gains and good gains. If short rams where a waste of money, and not good, copanies would not have sold them. So just think about it.
What do you think you're gaining? The TL can't outflow the stock paper filter. It is not a restriction so what is a higher flowing filter going to do? The TL already has a semi-cold air induction. You're now cutting it off and feeding the engine hot engine bay air. Where's the gain?
Don't believe dyno graphs supplied by the manufacturer. If you believe that, well I'm sorry. The only valid way to measure is to take your own car to the dyno, make a base run with the stock intake tract WITH THE HOOD DOWN TO SIMULATE REAL WORLD CONDITIONS and install the short ram and run it back to back with the hood closed. Dynoing a short ram with the hood up is invalid because the hood being up is the same as having a CAI.
Again, why waste money on something that will cost you hp? Do you really like the sound that much?
They're sold because people continue to buy them.
I'll concede that the gains may be a little bit better with the CAI (under certain conditions), but I certainly didn't feel a loss in power (Says the butt dyno).
What I did gain though is a noticeably quicker throttle response (over stock).
To each their own I suppose...
not for nothing, just sharing some info but I think you are exaggerating just a lil when saying you lose HP, free flowing air versus restricted oem intake, whether short ram or cai a difference will be felt over stock, that has been proven time and time again.....im not going to preach about short ram vs. cai, but long story short cai has its advantages on certain circumstances....even if you notice how the weapon r intake is positioned that filter is much closer to fender then engine itself, but to each its own, just wanted to put my 2 cents....all i know is power will not be lost when going to short ram....i have witnessed the gains from short ram and cai, so to say you lose power i would like to see some numbers to back your theory on how you lose power.........
also not to mention with the SRI, once u remove the stock intake tract, there is no way the air is directed up towards the filter. thats why people say u suck in hot air. granted, u get some cold, but its probably 75/25 in favor of hot air. it doesnt matter how far the filter is from the engine, there TL engine gets hot as f&*k
I have to question the statement that the motor will not outflow the stock air intake system. If that is the case, why do the motors show an increase in horsepower and torque when a cia is installed. You can't say "its because the hood is open when the dyno is ran", because the hood is up on the base line.
this is an SRI / WAI discussion not CAI.. nobody made such comments.
A CAI gains are from drawing in cooler air with low restriction.. the consequence is poor filtration usually because many CAI utilize a foam filter. A SRI on the TL draws in air from the engine and air from the resonator box / funnel so you don't fully benefit from the cooler temps. A CAI will have cooler IM temp than the SRI.
"What do you think you're gaining? The TL can't outflow the stock paper filter. It is not a restriction so what is a higher flowing filter going to do? The TL already has a semi-cold air induction. You're now cutting it off and feeding the engine hot engine bay air. Where's the gain?"
This is the statement that I am questioning. If you look, our stock system draws air from in front of the battery (don't believe me, take off the cover over the battery and remove the small triangle plastic piece between the battery and headlight and there is the intake duct), when the car is stopped there is no cool air being forced up the air duct by the fog light so the engine in drawing in hot air. Even when the car is moving, the intake is not drawing the outside air, but whatever outside air is mixing with the hot engine compartment air if front of the battery (right next to the radiator by the way).
2007 A-Spec Type S
O'boy...this is the never ending argument. I just want to post a link... Blue Rocket's homemade short intake.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/blues-custom-type-s-intake-688562/
Ok, I conceed that the SRI would be drawing warmer air than the stock intake system. But would the increase in temprature really out weigh the reduction in restriction? I guess my real question is has anyone based the argument of "you are loosing horse-power with a SRI" on real data? Has anyone taken data-logs of IAT with stock intake system compared to SRI? It seems everyone is caught up on the increase in temprature but there has to be a gain in air flow. I agree that the engine does not out flow the air filter, but does the resonator not serve as a kind of "air restrictor" at anything other that idle? You are still drawing air through the small opening of the funnel.
all i need to say is 2 each it's own and numbers never lie.....this discussion is like trying to convince a V8 guru that a 4-banger is better or vise-versa......anyways if someone has numbers of stock vs SRI please share, i wish i still had the numbers when we tested our stock vs. sri, granted it was not a TL, rather a 2003 civic si, but it was still stock vs. SRI
^^^^^was the hood open?
this is about the 3g TL not a civic.....just cause a mod made power on one car, doesnt mean it will do the same on another... FYI, power was lost with a CAI in an S2k...see where im going with this.....one car might have a very restrictive induction system, while another might be superior....while these manufactures cant test their product on every car...they will try and test them on a car that will offer a few gains for marketing purposes and save themselves from lying. but it couldn't be true for every other car
A Velocity stacker is a great add on. Mine is behind the bumper, where the fog light goes. Behind the stacker is the filter than the engine. its pretty cool, something like the civic guys would put.
"You will lose power"....i love how some people say this with a certainty like if they designed it or dyno'ed it....your comment is your theory/opinion. None of us know for sure until someone does some dyno testing under the correct circumstances.
My theory is that SRI offer slight gains over stock intake. I think the slight gains come in at low RPM's where the positive affect of more air flow is slightly bigger than the negative affects of hotter air. As RPM's increase i think the negative gains from the hotter (larger volume) air becomes more critical and you lose any positive gains (maybe go into negative gains). Having said that, i also believe the slight lower RPM gain will offer a better than stock throttle response. For people like me who use the TL as their daily driver and are not going full throttle every day this slight improvement in low-RPM throttle response might be worth the $200 for a SRI (and no hydro-lock worries).
Disclaimer: I still believe a CAI is the best intake option (definately better SRI). But for us sissies who are scared of some water killing our engine an SRI is still a viable option.
or better yet...just remove the duct from TB to filter box, and just clamp a filter on the TB...there ya removed the long path of air ...
ORRRRRRr even better.....dont clamp a filter on the TB, just throw a puma sock over it and throw a rubber band around to hold it in place.... you just completely removed any restrictions
^^^^^^^^^ kidding...
ts not true that increased flow is better being hotter, over less flow but cooler....not to mention you couldn't make a big enough difference on the 3g TL either way
ECU will pull timing with more air and hotter IATs but it wont with less and cooler IATs
Our ECU doesnt even like to play with injectors much either, it is designed to run as lean as it safely can for emissions and fuel economy (this holds true for below 3k rpm..it runs completely lean, in closed loop)...so dont even think that the increased flow is making the ECU add fuel to make up for the extra air, resulting in more power.. it mainly plays with ignition timing depending on IATs and few other parameters.
SRI will feel nice in the morning when ya first start ur car...but once you've been driving on stop and go traffic in 90 degree weather, and the engine bay turns into a pizza oven, you wont like it much...most of the air it will be sucking, will be from the fans withdrawing air through the radiator blasting it through the engine bay, which of course has nowhere to go.
and this hydrolocking issue...is anyone reading the posts on this? ur not gonna hydrolock unless u took ur car diving...dont blast through 3 feet of water.
dont believe the dynos stated by manufacturers, they are not even done in real life setup...its simply a marketing tool...nothing more...and there's nothing more eye catching than results, but the bad thing is, they're manipulated
think about it...some of us are big on modding our cars...dont you think we'd done it? there's nothing in it for us, because we're not trying to drift you off one product and push you for a different one. At the end of the day, we could care less about what you decide to do
and keep an open mind that not every car is the same....this is about our 3g TL... while another car may have a very restrictive induction system, which would benefit even if you blew a torch inside the TB (figure of speech.
