Second resonator behind J-pipe to get rid of drone?
Old Aug 22, 2012 | 12:57 AM
crbnfbr's Avatar
I already have a Magnaflow resonator toward the rear of the exhaust, and I was wondering if anyone has used a resonator right behind the J-pipe. I've been looking at this
Vibrant 1793 resonator Vibrant 1793 resonator
I'm trying to get rid of a drone that I have pretty much exactly at 3000rpm.
Old Aug 22, 2012 | 07:07 AM
Sure. Try it.
Exhaust noises is all experimentation.
People SPEND a lot of money just to get the sound they want.
and you cruise at 3k!??!?
Old Aug 22, 2012 | 09:15 AM
EvilVirus's Avatar
^ agree
OP try it out and keep us post it on how it turns out.
Old Aug 22, 2012 | 09:39 AM
crbnfbr's Avatar
NO, it's only when I accelerate through 3,000rpm. I suppose I could have called it more or a rasp than a drone really.
I'm not sure I'll be able to fit a resonator behind the J-pipe as the Magnaflow is on 18" behind the flange, and there's a slight bend in the tube.
Old Aug 22, 2012 | 12:53 PM
Bruce Banner's Avatar
Wouldn't a muffler get rid of drone more
Old Aug 22, 2012 | 01:00 PM
crbnfbr's Avatar
Probably, but there's not a whole lot of room in the tunnel behind the J-pipe. Plus it'd probably stick out too low, and my J-pipe already scrapes the ground on occasion.
Old Aug 22, 2012 | 01:21 PM
There is a spot for an OEM muffler behind the jpipe, unless you have something else there,
Old Aug 22, 2012 | 01:57 PM
swoosh's Avatar
takin care of Business in
trial and error mang....replace that magnaflow resonator you have with a longer resonator or a vibrant resonator...
Old Aug 22, 2012 | 02:30 PM
crbnfbr's Avatar
I suppose if I could find a small enough muffler I'd be able to mount it behind the J-pipe.
A Vibrant resonator is exactly at what I was looking at getting. I'm just not sure about their standard or ultra quite version.
Old Aug 22, 2012 | 02:41 PM
Why can't you find one? The OEM muffler fits, there's even a designated spot for it.
If you want the resonator more, just buy the ultra and be done with the drone
Old Aug 22, 2012 | 02:44 PM
swoosh's Avatar
too many or too long resonators will hurt the exhaust performance....
Old Aug 22, 2012 | 02:54 PM
crbnfbr's Avatar
Well, the issue is when I had my custom exhaust done they moved the Magnaflow resonator essentially where the old mid muffler used to be. That's why I'm worried about trying to find a muffler to fit where the original resonator was.
Old Aug 22, 2012 | 08:02 PM
hondazex's Avatar
put magnaflow hi-flow cat direct after the j-pipe with magnaflow resonator direct after the hi-flow cat !!
Old Aug 22, 2012 | 08:14 PM
350's Avatar
350
My first ricer
Dynomax bullet or mini bullet should fit, and they're pretty much under $40.
Old Sep 1, 2012 | 12:53 PM
The Machine's Avatar
Registered Member
I updated a thread I made by mistake and forgot this one existed. I updated both mine and this one in case someone in the future searches this topic, they can at least find an answer.
My Old Setup:
RV6 V3 J-pipe, mid muffler delete, dynomax resonator part # 24215 It had some rasp as well as some drone in 5th gear (AT) around 45-50 mph. The only way I can describe the sound is if you were to put a MT car in 5th gear doing 40mph. It was like a drone/bogging type sound with this resonator.
My New Setup:
RV6 V3 J-pipe, mid muffler delete, dynomax resonator part # 24235
Still has a nice tone to the exhaust, but the drone is gone in 5th gear as well as the rasp under normal and hard acceleration.
Here is a pic of all 3 resonators together: stock and the 2 dynomax
Old Sep 1, 2012 | 01:01 PM
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/adding-second-resonator-867060/
Old Sep 1, 2012 | 01:05 PM
Registered Member
^^ Yes, that was the thread I made by mistake. I updated that as well as this thread with the same info, so people can avoid making the same mistake I did (creating another thread when one just like it already exists). I just wanted people no matter which thread they looked in to have an answer.
Old Sep 1, 2012 | 01:24 PM
There is a better way, asked to have it locked.
DerrickW
Nov 15, 2015 05:52 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
kb1rl
Sep 30, 2015 10:17 AM
merc009
Sep 29, 2015 03:06 PM
