Notices
Saving4aTL Comptech/Rotrex Supercharger
Old 01-14-2018, 05:38 PM
  #241
OsK
Registered Member
OsK's Avatar
Originally Posted by 04WDPSeDaN View Post
Well... Yes and No.
Specially selected dealerships offered Comptech performance items as an add-on and or can be installed. The dealership I had worked for, did offer this. They still had Comptech parts in their inventory. This was a short period run since most customers weren't dropping 6K for the blower and another 1K for installation. Perhaps out of all the 3rd gen TL's and 1st gen TSX, maybe 2% actually bought their vehicles new with comtech performance items added. True story, my TL was actually bought from a dealership (In NJ) that offered the Comptech performance parts. The original owner was ready to pull the trigger on a blower but never did. I'm friends with the guy on Facebook and he's still shocked I have the car still and it's in flawless condition (plus boosted). He offered to buy it back a few times, but I keep saying No
No No, not today. Lmao.
Seriously though,
You can google when Comptech teamed up with Acura (Some dealerships) and what they offered.
You basically answered my question for me. No factory options. Dealers offered aftermarket Comptech Add-Ons (Intake "Icebox", Exhaust, Supercharger)
So, again, no factory boosted applications.....
K23A1 RDX doesn't count. We're talking about the 3G TL
OsK is offline
Old 01-14-2018, 07:28 PM
  #242
Rotrex + Comptech TLer
Saving4aTL's Avatar
Oi...
Your absolutely right OsK! Glad you split that hair for us!
I'm about to modify all the RDX 410cc injectors. Ill go get the I/M gasket and remove the I/M to get near the fuel rail.
https://acurazine.com/forums/second-...-tl-cl-716741/
I'm following this thread to a T. Anyone know another thread I can leech info from?
Saving4aTL is offline
Old 01-14-2018, 07:47 PM
  #243
Registered Member
Like I said when I pointed you to this thread, it was only for the connector repinning, it's a 2nd gen thread.
Before you start cutting and grinding on the injectors, try the fit on the rails and runners first. I didn't have to do anything and I don't think I ever read anyone else doing anything except lube up the orings and pop them in.
I still have my RDX injectors, let me find them and I'll post a pic.
KN_TL is offline
Old 01-14-2018, 08:35 PM
  #244
Saving4aTL's Avatar
Thank you for the post. I'm currently in my garage with dremel in hand(goggles on) and thought, "Lets check the build thread first".
Old 01-14-2018, 09:58 PM
  #245
Saving4aTL's Avatar
Doing research on Intake manifold removal. Can I reuse any of my OEM gaskets when removing plenum and I/M to gain access to the fuel rails?
Old 01-14-2018, 10:29 PM
  #246
3.5 psi
gnuts's Avatar
I've reused all the metal gaskets several times. Just clean them up before reinstall.
gnuts is online now
teh CL (01-15-2018)
Old 01-14-2018, 11:50 PM
  #247
Saving4aTL's Avatar
Are the plenum cover gasket and the I/M gaskets both metal?
Old 01-15-2018, 09:19 AM
  #248
rockstar143's Avatar
Received 15,079 Likes on 11,227 Posts
rockstar143 is online now
Saving4aTL (01-15-2018)
Old 01-15-2018, 11:50 AM
  #249
Saving4aTL's Avatar
Perfect! No need to spend $89 for the set. This makes the injector install easier.
Old 01-15-2018, 12:01 PM
  #250
Saving4aTL's Avatar
Installed used OEM ASM type S rear bumper for the quad ATLP.
Throttle body coolant bypass: looped the line. Used another hose to loop the inlet/outlet coolant line to the TB. Used third hose to loop the metal tube connected to the vacuum tube going to the intake.
No extra parts needed to achieve. Only Neednose pliers for clamps. Did this to lower intake temps after s/C install.
Old 01-15-2018, 03:17 PM
  #251
I often wondered if this was a placebo mod...
I had it done on my both my TL's...
Old 01-15-2018, 03:49 PM
  #252
Registered Member
Here are some pics for you
Attached Thumbnails Saving4aTL Comptech/Rotrex Supercharger-id1000.jpg   Saving4aTL Comptech/Rotrex Supercharger-injector1.jpg   Saving4aTL Comptech/Rotrex Supercharger-injector2.jpg   Saving4aTL Comptech/Rotrex Supercharger-injector3.jpg
KN_TL is offline
Old 01-15-2018, 03:54 PM
  #253
Saving4aTL's Avatar
It may be, but if it gets my intake temps a couple degrees cooler after boostering then I'm happy for it.
Old 01-15-2018, 03:55 PM
  #254
Definitely...
in FL summer heatsoak was legit on the TL.
I did the cooling mod thing too and it helped.
Old 01-15-2018, 03:56 PM
  #255
Saving4aTL's Avatar
Those look plug and play to me! Thank you for he measurements. I'll see if they coincide with the rdx today
Old 01-15-2018, 03:59 PM
  #256
does he have bigger one than you?
Old 01-15-2018, 06:24 PM
  #257
Saving4aTL's Avatar
We talking about penis or injectors? ...or both
Old 01-15-2018, 08:32 PM
  #258
Saving4aTL's Avatar
Hey fellas, what are the torque specs for plenum and I/M manifold?
I'm reading to tighten the I/M to 16 lbs and the plenum to 9lbs. is this correct?
Old 01-15-2018, 08:42 PM
  #259
Registered Member
U need to get the factory service manual......
Attached Thumbnails Saving4aTL Comptech/Rotrex Supercharger-2018-01-15_21-40-29.jpg
KN_TL is offline
Old 01-15-2018, 08:43 PM
  #260
Saving4aTL's Avatar
Thank you!
My torque wrench starts at 10lbs. The plenum spec is 8.8lbs. Would there be an adverse affect to overtorqueing to 10lbs?
I just remembered I have the haines manual.. Going to study that so I'm not caught with my pants down on injector D-Day.
Old 01-16-2018, 06:31 AM
  #261
Registered Member
Those cover bolts are pretty soft....I broke a couple my first time then invested in torque wrenches and spare bolts.
KN_TL is offline
Saving4aTL (01-16-2018)
Old 01-16-2018, 06:39 AM
  #262
Anything under 10 I hand tighten, palming a 1/4" ratchet.
always Penis.
Old 01-16-2018, 04:27 PM
  #263
Registered Member
Joecop67's Avatar
Always penis? Man I'm too old for this forum, I have no idea what that means.
Joecop67 is offline
Old 01-16-2018, 09:30 PM
  #264
Saving4aTL's Avatar
It finally came!(skeet)
How are the fresh from RV6 HFPC
Wanted to install these this weekend, but need ceramic coating.
Just to make it clear. We cannot heat wrap our HFPC fellas.
Old 01-16-2018, 10:40 PM
  #265
Registered Member
thisaznboi88's Avatar
Send it to swinetech. They have really good coating
thisaznboi88 is offline
Old 01-16-2018, 10:52 PM
  #266
Registered Member
dopeboy1's Avatar
Why does that paper with installation tips repeatedly say precat deletes when you have HFPCs? Is it possible they sent you the wrong paper? The paper that came with mine says HFPCs and nowhere mentions pcd. It also nowhere mentions anything about wrapping them with exhaust wrap.
I also don't see why they cant be wrapped if they can be ceramic coated....
dopeboy1 is offline
Old 01-16-2018, 11:09 PM
  #267
Saving4aTL's Avatar
There are a few places locally I'm getting quotes on. Don't want to ship them out after they just came in.
Old 01-16-2018, 11:55 PM
  #268
Registered Member
Old 01-17-2018, 07:17 AM
  #269
Saving4aTL's Avatar
Your right, it is. Ill see if anyone can match the quality locally. If not, this is a good option and price point.
Old 01-24-2018, 11:25 AM
  #270
Registered Member
6spd-GERCO's Avatar
In for updates
6spd-GERCO is offline
Old 01-24-2018, 11:15 PM
  #271
Saving4aTL's Avatar
I've completed the battery relocation to the trunk.
RV6 HFPCs should be finished getting black ceramic coating in the next five days.
Injectors go in this Saturday. HFPC on Sunday, if I get them back in time.
Purchased OEM side skirts today on eBay for $220 shipped, completing the type-S kit. Wish ATLP still offered single tip exhausts.
Old 01-27-2018, 11:02 PM
  #272
Saving4aTL's Avatar
Injector install
Old 01-27-2018, 11:04 PM
  #273
Saving4aTL's Avatar
How was this possible?
#10%er MPG
Old 01-28-2018, 12:04 AM
  #274
Registered Member
lol duty cycle like 40% on those on a N.A car
Old 01-28-2018, 12:23 AM
  #275
Saving4aTL's Avatar
Does the ECU use the duty cycle numbers to read gauge the MPG?
I found the that my engine bay temps are considerably lower than they were before installing the injectors and getting a new tune from DomGSR.
RV6 HFPC are ready for pick up this Monday. Next Sunday is the install day.
Old 01-28-2018, 12:36 AM
  #276
Registered Member
that would be my guess since duty cycle is dictated by injector pulse width. and that is dictated by load and rpm
Old 01-28-2018, 05:17 PM
  #277
Saving4aTL's Avatar
Anyone heard of this guys shop?
Old 01-28-2018, 05:21 PM
  #278
Saving4aTL's Avatar
I tried to make it as clean of an install as possible.
It took me 14 hours!!
Making way for the Supercharger.
Old 01-28-2018, 06:53 PM
  #279
Registered Member
How did the reseal process go for the S/C'er unit? What oil did you settle on?
zeta is offline
Old 01-28-2018, 08:12 PM
  #280
Saving4aTL's Avatar
I plan to reseal the S/C next weekend. The loctite you suggested is waiting in the garage.
Ordered 10qt of Redline High Temp ATF and x2 bottles AC Delco GM Supercharger oil today.
I'm picking up my HFPCs from the ceramic coating shop tomorrow, will post pics.
Quick Reply: Saving4aTL Comptech/Rotrex Supercharger
