Notices
Saving4aTL Comptech/Rotrex Supercharger
Old 07-02-2018, 02:16 PM
  #361
Rotrex + Comptech TLer
Saving4aTL's Avatar
This install was more difficult than I anticipated. There were clearance issues. The transmission is different in the 07-08 T, so mine didn’t fit and I had to cut it to make er’ fit. The radiator hoses had to be carefully selected for the proper 90 degree angles. I had to cut 1.25” galvanized piping for the coupling.
The most difficult cult part is the starter positive bolt, which sits higher on the 07-08 and is impossible to install without trimming the bolt to a nub. This weekend I will have to use a 400/60 solder gun, liquid flux and silver solder and solder the positive he wore to the nub. I also bought liquid electrical tape to paste onto the underbelly of the supercharger. A 1/8 inch rubber gasket will sit between the starter bolt nub and the S/C underbelly to make sure electricity going to the starter does not transfer to the S/C.
i am going to use my stick alternator bracket and have pacific metal fab an extension to make it have two bolt holes instead of one.
Saving4aTL is offline
The following 2 users liked this post by Saving4aTL:
EvilVirus (07-03-2018), zeta (07-02-2018)
Old 07-03-2018, 08:56 AM
  #362
Saving4aTL's Avatar
Still A lot of work ahead. S/C needs to be removed. Alternator pulley bracket needs to be installed. Need to shave down the rest of the starter terminal bolt and solder the wire to the flat metal. Need to heavily insulate the starter bolt so that the electricity does not arc onto the S/C. Need to drain and fill the radiator again. Move the power steering pulley hose away from S/C pulley. Reinstall all components and upload the DomGSRís Hondata S/C map. Ignition and testing begins!
zeta (07-03-2018)
Old 07-03-2018, 10:57 AM
  #363
Registered Member
I can see from the pictures how it looks like the PS hose 'juts up' close to / into the path of the drive belt at the top.
I guess you didn't get the Power Steering Adapter #355-146 and its 6x14 bolt when the seller removed it from the previous car.
zeta is offline
  #364
Registered Member
Was that type s a manual or auto? Looked like a close race, you currently have PCDs and exhaust on the car? SC install looking good so far, good luck with the little issues
90foxnotch is offline
Old 07-03-2018, 01:33 PM
  #365
Saving4aTL's Avatar
I’m going to fab a metal plate to keep it away from the P/S hose. My issue is the new outlet price that comes out from the P/S module. Is this a critical part? It’s the one that goes travels under the serpentine belt.
i have a 2008 auto. I have rv6 high flow precats.
im planning to make two tunes. One For standard 92 octane fuel, and another for 100 octane for the track.
Old 07-03-2018, 01:59 PM
  #366
Registered Member
Originally Posted by Saving4aTL View Post
My issue is the new outlet price that comes out from the P/S module. Is this a critical part? Itís the one that goes travels under the serpentine belt.
I'm not sure what you mean by 'outlet price'?
If you have not done so already, reference Step#11 on the link below. It shows the P/S adapter that was provided by CT Engineering to divert the P/S hose to the side, rather than 'up' as it is now.
http://www.ct-engineering.com/Portal...-SCKit2009.pdf
That adapter piece is shown in the picture on the first page, to the left of the alternator bracket you are missing as well.
zeta is offline
Saving4aTL (07-27-2018)
Old 07-03-2018, 04:04 PM
  #367
Registered Member
Saving4aTL,
56123-RCA-A01 ($7.01) is the part number for the P/S inlet for your 08 TL, which points upward.
https://www.hondapartsnow.com/genuin...3-rca-a01.html
56123-PVF-A01 ($4.37) is the part number for the P/S inlet for an '03 CLS, which points to the side. This is what you need to keep that P/S hose away from the drive belt.
https://www.hondapartsnow.com/genuin...3-pvf-a01.html
Since the 'prefix' and 'suffix' of the two part #'s are the same, there is a reasonable probability the CLS6 one may work on your 08 TL.
However, you will have to gamble the $4.37 cost before shipping to see if it works. Though it would solve your problem.
zeta is offline
Old 07-03-2018, 06:20 PM
  #368
Saving4aTL's Avatar
Zeta Your a gem! I ment outlet piece, not price. Autospell
I ordered the part your suggested and overnighted it.
Old 07-03-2018, 06:31 PM
  #369
Registered Member
When I saw the one provided by CTE on the install instructions for the TL, and how it pointed sideways, I went out and looked at the one on my car and it was pointing sideways as well. So I thought I would see what the Part #'s looked like, and they looked similar; therefore, the possibility of it working on your car, at this point in your install, seemed reasonable. All that was left was presenting my case and your gamble of $4.37+shipping.
Hopefully, it works and you'll have one less issue to work around.
zeta is offline
Old 07-04-2018, 03:18 AM
  #370
Saving4aTL's Avatar
Making a datalog for Dom-GSR to tune, heís a
wizard
Shadow2056 (07-09-2018)
Old 07-04-2018, 12:18 PM
  #371
Saving4aTL's Avatar
Going to install the AEM water/meth system this weekend. I got a bottle of boost juice ready.
Old 07-05-2018, 08:16 AM
  #372
Registered Member
Damn I didn't think that thing would whine that much, Sounds like a mini Terminator! Good luck with the tuning
Old 07-05-2018, 01:39 PM
  #373
Saving4aTL's Avatar
machine Shop did a good job 👍🏻
EvilVirus (07-05-2018), zeta (07-05-2018)
Old 07-05-2018, 01:51 PM
  #374
Saving4aTL's Avatar
Iím half way through the water/meth install. I ran the hose front he truck/under the car/into engine bay. Drilled a hole in the firewall to connect the boost hose to the control unit under the dash. I Tíd into the supercharger wastegate boost line so that the control unit gets boost levels. The wires were ran through the interior on the drivers side. You will only have enough wiring to run along the side of the car where you choose your control unit to be on.
I still have to:
- Wiring in the trunk
- Mount the pump
- Mount the fuel reservior
- Mount my wife
I will also be installing the transmission cooler. I believe itís a must if you choose to boost our heatsoak loving cars. Does anyone have a good install thread for the 2007-2008 Acura TL?
Iíve read all I can on it and still donít know where to tap into the tranny lines due to pictures not showing up on the install threads.
Old 07-05-2018, 04:37 PM
  #375
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,205 Likes on 811 Posts
Take pics of the last mounting you do!
gatrhumpy is offline
Old 07-05-2018, 09:00 PM
  #376
Registered Member
Duronn's Avatar
I would recommend you add a water methanol solenoid to prevent any siphoning of methanol when not in use.
Duronn is offline
Old 07-06-2018, 12:33 AM
  #377
Saving4aTL's Avatar
Isnít it beautiful?
Old 07-06-2018, 06:24 AM
  #378
Registered Member
Nice!
So, the CLS P/S inlet was No Bueno?
And that's why the whine is so loud in the cabin, you are running a straight CAI to the throttle body.
Congrats on your project.
zeta is offline
Old 07-06-2018, 07:08 AM
  #379
rockstar143's Avatar
Received 15,057 Likes on 11,209 Posts
well shit, I've avoided this thread thinking you were all talk and it was just bs going on in here. Congrats on getting it up and running!
rockstar143 is offline
Old 07-06-2018, 07:09 AM
  #380
Saving4aTL's Avatar
The intake should be here Monday. I used zip ties to temporarily tie the hose out da way.
Zeta, Iím eyeballing the Stage 3.5 kit from Gerzand...
Old 07-06-2018, 07:12 AM
  #381
Saving4aTL's Avatar
Originally Posted by zeta View Post
Nice!
I did a test run with the cone filter mounted onto the throttle body. That was ear piercing after 5k rpm
Old 07-06-2018, 07:14 AM
  #382
Saving4aTL's Avatar
At times I do talk too much when not IRL, you but I enjoy getting work completed.
Old 07-06-2018, 07:16 AM
  #383
Clearly...
I was always tempted to SC, or at the very least see how much of a difference it made in enjoying the drive...not even WOT, just around town where you do most of your driving anyway.
Looks like a hoot.
Old 07-06-2018, 08:59 AM
  #384
Saving4aTL's Avatar
Ya itís a lot of fun, a nice noise maker. The gains are there, but I would like to do the max to a 3.2 j series on a boosted application. Iím still doing research. I may buy Andyís stage 3.5 kit.
First, ill keep it at 425whp. Then build the motor for 550-570whp. From my calculation, this is achievable with a 3.2l 5AT.
Old 07-06-2018, 10:10 AM
  #385
Registered Member
Oh, OK. So there is still a chance. I saw the zip ties, nice improvisation.
Nice!
Try this one out for a month or two. I bet you won't be able to keep your foot off the accelerator, hehe. Car-part.com has plenty of 2008 3.2's available in the northwest should you need one.
Good Luck!
zeta is offline
Old 07-06-2018, 10:25 AM
  #386
I'd be more on the lookout for a 6MT than the motor
Old 07-06-2018, 10:54 AM
  #387
Registered Member
Like this one?
https://acurazine.com/forums/market/971290
zeta is offline
Old 07-06-2018, 11:15 AM
  #388
Saving4aTL's Avatar
If I would go 6mt Iíll get the 07-08 type S. I like their transmissions and the updated Interior/Exterior. Perhaps Iíll build this motor up and eventually get a 6mt and transfer everything. Iíd like to buy a 3.5l motor and slowly build it for boost.
I love the 3g, no other car has held my enthusiasm like this one( besides the turbo 98 civic EX when I was 19).
im going to rid this s/c and keep it even if I purchase the stage 3.5. Everything is modded for it already. If I do someday get a 6mt type S, I can use my current cat with the CT S/C as a daily.
Old 07-06-2018, 02:54 PM
  #389
Saving4aTL's Avatar
These are all dreams though. I probably will stay auto. Keep my car.
Old 07-08-2018, 04:13 PM
  #390
Saving4aTL's Avatar
Is there anyone that would be willing to send me thier fuel crusher device from Comptech? Im not able to get ahold of Nick at CT.
I will pay shipping both ways. I appreciate any help with this.
I installed a watermeth system this weekend!
Old 07-08-2018, 04:59 PM
  #391
Registered Member
Just an FYI. Check out post #3 on the thread below. I don't know though if the info is accurate.
https://acurazine.com/forums/3g-tl-p...rusher-827783/
zeta is offline
Old 07-08-2018, 07:53 PM
  #392
Saving4aTL's Avatar
Thanks Zeta! Iím still waiting on the power steering outlet piece.
I would like to install the DW65c into it just to ensure good flow.
zeta (07-08-2018)
Old 07-09-2018, 12:28 AM
  #393
Saving4aTL's Avatar
Is this too much boost? When tuning began It was difficult to get over 3.6 psi. At this point Iíve seen 9.4psi at the end of the rpm range at WOT on 3rd gear pulls.
How much hp/tq could I be making with this amount of boost?
Old 07-09-2018, 06:17 AM
  #394
probably over 1000
Old 07-09-2018, 08:15 AM
  #395
Saving4aTL's Avatar
probably over 1000
Cant be. I was getting that with my eBay turbo exhaust whistle.
Old 07-09-2018, 08:47 AM
  #396
yeah but now it's wheel, not crank!
Old 07-09-2018, 09:41 AM
  #397
Registered Member
horseshoez's Avatar
Another thing to consider when trying to figure out net horsepower from a supercharged car is perform a rough gross power calculation (rated horsepower (258) times the net overboost (14.9+9.1)/14.9, or said another way, 258 * 1.61 = 415 hp), LESS the draw of the supercharger (I don't know the draw of the unit in this thread, but I've seen published numbers as high as 40-60 HP for such units). Said another way, your engine may well be putting out say 415 hp and yet at the crank you are only netting out to something like 355 hp, and given the slushbox transmission in this car, the power to the wheels will be even less, maybe only as high as 310 or 320.
horseshoez is offline
Old 07-09-2018, 02:47 PM
  #398
-------Tim-------
Slpr04UA6's Avatar
Nice Updates Saving4aTL!
On the HP #, I’d say maybe 260hp to the wheels. Aren’t auto’s Around 210hp factory to the wheels? Then add 50-60hp.....
Who cars tho, that Whine is I’m sure nice to hear!
Slpr04UA6 is offline
Old 07-09-2018, 03:19 PM
  #399
Saving4aTL's Avatar
I read this S/C gives 40-60whp, at 3.5-5psi. But what about 9.4psi? 100whp?
Using Hondata, I calculated that I went from 70-100 in 5.87 seconds. Thatís just a hair faster than the 6.0 second 2007 type-s.
Though its still in the tuning process. Iím installing a DW65c fuel pump this week, due to having intermittent drop in power at high rpms. It feels like it isnít accelerating, but my car is whining hard. Not sure if that will fix it. It could be my 1 step colder spark plugs. Should I be using iridium or copper plugs?
Getting Michelin pilot sport PS 4s his Friday from Costco. It will help my quarter mile.
Old 07-09-2018, 03:27 PM
  #400
Registered Member
horseshoez's Avatar
My calculations above were for 9.1 psi over MSL; they yielded a 157 HP bump in the gross power (258) of the engine, however, because this is a supercharger application you'll never see all of that new power. Given the supercharger will draw back a significant percentage of that increase, a net increase of 100 HP is certainly possible.
Quick Reply: Saving4aTL Comptech/Rotrex Supercharger
