RV6 precats and Jpipe done
I finally got them installed today, OMG its loud i dont knoe if that is normal but it is quite loud with my stage 1 exhaust. Dont get me wrong but wow i wasnt expecting that much increase in sound. I also noticce a small drop in power under 3k that everybody notices but it just explodes after that. I got a lil bit if rasp between 2-3k but its actually kinda nice, it gets replaced by a G35 like growl after 3500. Before driving the car i let it idle for 10 min. Does it really get louder after a few days? More power?
think of it like this, take 2 soda bottles, and connect them at the opening. when u move the liquid back at forth it gets stuck and will slowly go into the other bottle. now if u cut the opening above the label, and connect it and move the liquid back and forth it will flow freely.
kinda like ur exhaust, drop the 3rd cat, get richie's race pipe, or test pipe for $65 i think
Yes, they do that here. If they look under the car, don't see a cat, you lose the car and it's crushed.
You guys are making this waaaay too difficult. If it's too loud or raspy, add a straight through muffler somewhere in the exhaust system like in the 3rd cat location. The longer the muffler the quieter.
The 3rd cat is essentially a high flow cat. It may make a small difference if you remove it but not much.
I live in Irvine, CA...the cops will give you a fix it ticket/make you see a state judge just for a car that sounds "too loud"...I've had a lot of friends had their hoods popped.
i really need to do something about the smell...maybe put the stock 3rd cat back in i can't seem to forgo the extra punch to actually get rid of the entire setup all together though lol
It sounds funny to me. I'm old enough to remember when not every car had a convertor and the smell was just normal to me, in fact I never really thought about the smell. I remember the nights of running straight Av gas in the GN catless of course with my eyes watering and nose running from the sweet smell. People pulling up next to me looking over trying to figure out what the smell was and people who knew commenting that I was out to race.
Rasp is GONE!!! I added a long magnaflow resonator between the 3rd cat and stock res and now im left with a nice tone without rasp during accel all they way up to redline. I do notice a bit of rasp when i let off the throttle at high rpm but that i can deal with, its sounds, dare i say it, ferrari-ish. Any ways im totally happy with my exhaust now.
Time ti get that UR pulley installed.
Thanks for all thw feedback guys very much appreciated.
I will post some vid clips soon
btw, get your car fixed after the ZR1 run? dude, that was SWEET! lol
practicing nihilist
dynamax went out of business, i think. late, but I added a dynamax resonator to full RV6/Test Pipe/ATLP Base and it's very mellow and not cracking/droning/rasping. just enough to know it's there.
Nah, it's going to sit for a while. Can't afford to fix it and I'm just a few parts away from having the built motor ready so I'll have to upgrade the rear anyway. The goal is 850rwhp and streetable.
and i dont mean, raspiness throughout the entire rev band...i mean the specific "crack" at 3000 rpm
the car has a dual-stage intake manifold...opens at 3k.... while below 3k, the intake manifold is split into 2 sub-plenums (anyone whos ever looked inside, would've seen the butterfly) isolating 3 cylinders on one side, and 3 on the other...when butterfly opens up at 3k, the whole manifold becomes as 1 plenum...this changes how the air pressure acts for a split sec, resulting in a different cylinder filling...which causes that annoying "crack" at 3k
if you need a better and scientific explanation on how and what exactly happens inside a dual-stage intake manifold...do a little research on your own...i doubt youll find anywhere, saying about the exhaust sound change...but it will come to you
just say im the first one you ever heard it from
Under construction
I agree. It's pretty raspy during daily driving but that disappears when your doing 80mph fly by's (mine sounds very good at high speeds) I hate the rasp don't get me wrong, I'm still saving up for the ATLP exhaust.
Dual-Stage Intake Manifold
Like the RL and MDX, the TL utilizes a dual-stage intake manifold to boost performance across the powerband. Working in concert with VTEC, this manifold improves low-speed torque without sacrificing high rpm power. The manifold is divided into two banks with three cylinders fed by each bank. The powertrain control module (PCM) controls butterfly valves between each bank. At low engine speeds the valves are closed; each separate bank of the manifold is tuned to maximize the resonance effect of the incoming air and increase cylinder filling and the torque through the lower part of the engine's rpm range.
As the engine rpm rises, the resonance effect fades, and the butterfly valves connecting the two banks of the intake manifold open. Now the resonance from individual pressure pulsations is eliminated, and an inertia affect helps the mass of air rushing down each intake passage. This provides more charge than each cylinder would normally ingest, working like mild supercharging to enhance horsepower at high engine speeds. The manifold changeover rpm is set somewhat lower in the rpm range than is the VTEC changeover rpm. This works to smooth and broaden the torque delivery. More than 75 percent of the peak torque is available from 2100 rpm to 6500 rpm.
