Rotora Slotted Rotors and Brake Pads
So I just upgraded to the above mentioned combo, compliments of Excelerate who was great to work with, and I'm wondering how to best approach the brake-in process since I can't technically brake-in the pads until i brake-in the rotors while still using the pads to help brake in the rotors in the interim.
Any recommendations?
they used to come with instructions (last year) that had an extensive drive 35mph and use the brakes every 1 km for an unreal amount of miles.
Normal people- I think Josh would agree but call him to comfirm,
would do a series of warm up the pad slow downs from 35 and 45 to 10 mph, speeds approx
Just trying to get the casting whatevers and stuff off each part-like they were new tires.
drive to let cool off
Stop and let cool 15 minutes- this is called Greening the pads
Now go do it again with a bit more aggressive use of brake- more towards normal driving
drive on freeway to let them cool and park. Repeat this for a few days and then you can do it again and this time get the pads hot with aggressive braking, then do 2 60-40 mid application of brakes to cause a transfer layer of material to the rotors
Then give them 500 miles of normal use and they get really good and should be noise free after this procedure
The only thing to avoid is ABS stops.
When you replace the brakes and the brake lines and get air in the system really bad,
you have to do 2 abs stops to move the air along.
That would be a bummer for your new brakes
Maybe thats what the confusion of breaking in one part while not hurting the other?
The pads and rotors need to be intimate friends. Let them get to know each other on a dark lonely road
200,000 mile club
I just installed the Stoptech slotted/drilled rotors with posi quiet pads from excelerate. Great setup. I blead the system on all four calipers. The break in process was a pain in the ass. I am still trying to do some runs at 60-10mph. At first, the breaks are really poor due to the coating on the rotors and the new pads needing to heat up. After that, what a great setup. Getting better by the day. Leave yourself plenty of time to stop. I also have the brembo setup.
thanx for the info guys. i've certainly noticed a gradual increase in braking performance since getting them installed this weekend.
but i haven't really tried to break in the pads because the rotor instructions said no hard braking until they are fully broken in (approx 300 miles).
I usually cover that mileage in a week so I guess I'll start on breaking in the pads next weekend. I can't wait. I really, really, really dislike the OEM setup.
hard braking being 85-100 percent application force to the brakes- ABS and nearly ABS is what they want you to avoid- causes glazing and with the rapid on off- not good
Drive it and get the parts mated
'10 Hyundai Genesis Coupe
Yeah I'm thinking of upgrading my brakes as well, they are close to being worn out. I think I'll get stock size rotors and pads and paint the calipers black.
Thats a really good look--brakes painted all black like mini brembos- or bimbos~
Do the brackets too, or paint one part the car color and the other black.....
Get the centers of the rotors while you are there.
I wish I could just get a different caliper, that would have been optimal.
Making the mighty dollar
I agree Excelerate was great help, and I couldn't be happier with my Rotora slotted rotors and pads. No squeak or squils and very very little brake dust.
Originally Posted by Excelerate
Disclaimer- I dont know squat about gen3 cars~~~
On gen2 you can replace the stock front 1 piston calipers with a set of
dual piston calipers off the 1995 Legend LS -Coupe
Direct bolt up- except swap calipers left to right from intended use.
If the gen3s (Non brembo cars) use the same bracket, caliper and rotor as gen2, its a heck of an upgrade in braking force for $150 in parts and some labor.
Yeah I've heard about that mod, and I wish it would work that would be a great upgrade both aesthetically and in performance.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
