Rotora OE size Rotor ???
I
Sup fella's, I will be more than likely purchasing the Rotora rotors from an az vendor this week. But before I do. I was wondering if I could get some feedback from you guys as to is there a noticeable difference in brake power, Is it worth getting etc. I'd just like to hear the PRO'S and CON'S. Thanks in advance
The only difference might be less rotor warpage.
If you really want to improve your brake system, change the OEM brake pads for Hawk Performance Street pads.
I replaced my rotors and pads 1 week ago.
I purchase Racing Brake one piece slotted rotors along with Hawk Performance Ceramic pads. After the proper bedding procedures, the brakes have improved with a more responsive brake pedal.
The Racing Brake rotors also have a special curved vane design for the vented front rotors.
Check them out;
http://www.hawkperformance.com/performance/ceramic.php
http://www.racingbrake.com/main/rotor_vane_design.asp
Also, check out this thread in the Group Buy section for special offers on the above;
https://acurazine.com/forums/sponsored-sales-group-buys-10/racingbrake-front-rear-up-rotors-packages-deals-inside-344787/
Best regards from Montreal, Canada
frenchnew
Former Sponsor
Rotora’s brake discs feature special segmented slot, or drill & slot pattern, which is applied to the disc’s front and back surfaces to ensure maximum heat and gas dissipation for greater stopping power and minimize warping and cracking caused by repeated, high stress, high temperature braking.
Combined with a good pad like the ROTORA ceramic pad or the Hawk HPS pad, and even a set of stainless steel brake lines, you will notice a significant difference over stock.
ExcelerateRep
10-14-2015 08:20 AM
