Replacing Motor Mount
Has anyone replaced the motor mounts? Specifically the passanger side mount? It looks like there are just three bolts holding it in. Is it really that simple?
yes, lift the p/s reservoir off the bracket and basically unbolt everything then swap it. you may need to jack the engine up to take the pressure off. i used a small rubber block and a jack on the oil pain. dont use just the jack, you need something so the pressure is on the outsides of the oil pan.
