Recommendation for High Flow Cat
Bored at work
i got the rv6 pre cat deletes with the atlp high flowing cat in the middle...dont know if i would pass emissions i also have florida tags.....just as long as you leave the front two stock cats in you will be fine...the atlp high flow cat has tabs for the stock heat shield so it looks stock from underneath the car..
Former Sponsor
Random Tech makes a good 2.5" IN/OUT High Flow cat with 300 cell metallic core and stainless steel body:
http://store.excelerateperformance.c.../i-244036.aspx
winner
^^ no they are saying that since the third cat is not monitored by a sensor it will not throw any codes so more than likely you will be able to get away with it unless they do a thorough visual inspection...............but on the other hand it is illegal to remove any smog related devices so it is technically illegal by the letter of the law.
runnin a little boost
No, don't waste your $$$ on the type-s cats, as long as the substraight is not impeding exhaust flow thru the cats you are ok. If they fail just take out the substraight and run them like deletes.
Comptech exhaust are loud, put a hi flow 3rd cat on it to quiet it down.
joflewbyu2
10-08-2015 11:16 AM
