Radiator cap?
#ForcedInductionFamily
Radiator cap?
Did a search and didn't turn up anything. I was browsing through Excelerate's new website and saw that on a few of the radiator caps for sale there were claims about radiator efficiency increases by using them. Something to do with a stiffer spring in the cap creating more pressure and lowering the boiling point of the coolant? School me, I can't imagine that a simple cap would make a drastic difference on your cooling system.
94 DC4 RS LSV/Turbo
I've got a greddy one... 1.3... my friends rock skunk2 one's...
I like the skunk2 one better since it is black and red... if you want the greddy one holla at me...
AZ Community Team
Received 7,771 Likes
Increased pressure does in fact Increase the Boiling Point of a liquid up to the liquids "critical point".
Although I've heard of this before (High Pressure Radiator Caps), I don't see the point UNLESS you are reaching coolant temps above (or very near) the coolant boiling point.
As a reference:
Peak Long Life 50/50 = 226* Boiling Point (per MSDS)
Peak Global Life Time 50/50 = 226* Boiling Point (per MSDS)
Prestone 50/50 = 265* "Boil Over Protection"
Prestone Prime 50/50 = 265* "Boil Over Protection"
Valvoline/Zerex Original = 265* Boiling Point at 55% conc.
I *assume* Honda/Acura Coolant is similar: 250* - 275* Boiling Point at recommened dilution.
As a reference:
If the temp guage ever reads more than 1/2 in your TL- you have a problem
No cap is going to make the TL cool better
If you had a supercharger then we need to talk!
I have car ADD
no whiners
on that question.. i had a TL and a TL-S... my type-s, that temp gauge NEVER goes over like...1/3.. the TL would go up to about 3/8...
i was doing some reading last night, i never knew the type-s came with an external tranny fluid cooler.. unlike the base TL's... good to know
'10 Hyundai Genesis Coupe
Originally Posted by BLACKURA_NY
no whiners
AZ Community Team
Anybody know what the temps are for the Temp Guage? Also where is the Thermometer located - in a relatively "cool" place or a relatively "hot" one?
Mine guage sits dead center ('07 TL-S) once the car is up to temperature.
Also curious what is the MAX coolant temp anywhere in the cooling system? If the max temp approaches 250*, anywhere in the cooling system, then a high pressure cap *might* be marginally helpful.
My *guess* is that Stock, under "normal" conditions the max temp is well below 250-ish, so no chance the coolant will vaporize. But under extreme conditions, S/C, etc -
no whiners
AZ Community Team
dead center?? really? no kidding. mine will NEVER EVER go over 1/3 of the way up.. even when i drive 3 hours straight in the summer... hell, even why i dyno it or floor it...
Yeah. Really. I'll double check and watch it over the week-end - it's going to be HOT! HOT! HOT!, but I am 99.9% sure it's dead center and stays there once it gets warm.
AZ Community Team
Originally Posted by WRXtranceformed
My temperature gauge usually stays a few ticks under half on my 07 TL-S.
Forgot to post back. Mine is the same as yours - not dead center. It points dead to the right (3 o'clock position) but after looking closer, that is few ticks under dead center.
