R-V6 Pre Cat Delete Hissing noise?
Just got the package today and installed it asap.
It wasn't as hard as i thought it would be...finished in less then an hour... Everything fit perfectly, pipes were beautiful and no Engine lights. All i am hearing is this hissing noise; is it normal for these pipes? All my bolts lined up and are snugged up tight... Ideas? thanks! |
Originally Posted by Harrisonk531616
(Post 10492492)
It wasn't as hard as i thought it would be...finished in less then an hour... Everything fit perfectly, pipes were beautiful and no Engine lights. All i am hearing is this hissing noise; is it normal for these pipes? All my bolts lined up and are snugged up tight... Ideas? thanks! Wierd |
Uh oh...hope this doesn't turn into what happened last time with the j-pipes.
Originally Posted by ifirahse
(Post 10492667)
just how he fixed our problem |
did you install just the precat deletes... if you have a hissing sound check the flanges are even and linged up
the precat deletes no longer have flex section they are straight pipes... which jpipe are you guys running? because thats the only flex section left... I installed a set of the revised precat deletes and defininitely heard nothing |
OH NO. I am about to buy the special from Rich monday.
Relax dude its usually the flanges lol exhaust leak
There is nothing wrong with my precat deletes :shrug:
And jd, do it! You will be very happy! |
Installed in less then an hour! How did you manage that. I would check everything over the new precat deletes have no flex pipe to hiss and jpipes have the update flex pipes. Which jpipe are you running, could it be rasp? Precat deletes have been known to cause rasp with after market exhaust.
Wow, I guess I skipped that part where he said he installed it in under an hour :tomato:
I don't believe em, the fastest I've ever installed them was 2hours flat (bforbrian's car) It takes 1 hour just for the car to cool down :doh: |
Originally Posted by stillhere153
(Post 10493472)
I don't believe em, the fastest I've ever installed them was 2hours flat (bforbrian's car) It takes 1 hour just for the car to cool down :doh: The passenger fan takes what? 2 minutes to remove? Front cat "4" 12 mm with a deep socket and a air ratchet? another 3 mins? o2 sensor comes in what less then a minute with the right tools? Rear sway bar comes out in 3 minutes; 3 10mms attached on; the 6 12mms for the towers... then we have the 4 12s in the back which are just as easy...the o2 sensor maybe antoher 6 minutes... Now the car is lifted up and the j-pipe is disconnected; 6 14mms that come out with an impact gun...how long does that take? and the 3rd cat is disconnected another what? 2mins? shields come out with a 1/4" air ratchet with a 10.. and the two coils in the rear... All that was done in about 1/2... install was even quicker...because of the slimness of the pipes. I do cats on muranos in about an hour at work; where i have to take out the subframe and the cowl to take out the shields....\ And i just came back from work as well; car was only sitting for 10 mins...car does not have to be cooled down. im sorry you can't do it in about an hour. |
Took way longer than that for my car....its supercharged.
Oh.....I guess thats a bad example.....cause I did motor mounts at the same time....which was where the bitch came in with the supercharger being in the way. Handled it same way though....with the rad. |
(Post 10493608)
Just because you can't does not mean i cant...
I'd let'er cool down tho... burns ftl well like you said you used impact... so could it be when you tightened the jpipe to the precat the flange shifted slightly, and you know first wide open run you go it causing a blown gasket I say drop it, replace the gaskets with o2 sensor safe gasket maker then keep ur index finger near the 2 flanges to feel for a shift as you tighten... |
So the gaskets that richie provides break easily? So the gasket maker will fix this problem?
Richie provides OEM gaskets that are from honda. If you drop them or somethin, then there is a chance to break them
Originally Posted by greco9885
(Post 10493811)
^ yes those very gaskets (precat to jpipe)... I am not saying they are cheap, I am not saying they are good... I am just saying that I ran into this problem and replaced it with rtv or rvt whatever the hell its called (as per richie's aim message to me when I inquired)
some make threads, others talk to richie.. i find talking to richie solves the problem quicker than making a thread or you could get 2 sets of v-band clamps and do a little cut and weld ;)... but there aren't any tig welders in NY :'( |
(Post 10493941)
I would make sure the flanges are lined up with the jpipe and gaskets have not been crushed. They are made of graphite which can be squeezed if over tightened. I checked and you only purchased deletes your last purchase. What jpipe are you running, if it is mine when did you get it?
Originally Posted by JD TL-S
(Post 10492883)
Originally Posted by Richie v6
(Post 10494183)
I wont front i tighten them with the impact gun and then tap it 3 times afterward lol, but I do put my finger to make sure they are flush
I would believe not exceeding 50lbs is safe enough... although impact gun does what 100 lol |
i think its not the leak. its just extra noise that comes with the precat deletes(rasp). i had the hissing too and checked with several different mechanics, but found no leak at all.
mine dont hiss at all
but i do get that heatsheild rattle when the car is cold.... to think about it, when i FIRST installed the pre-cats, i thought i heard a hissing too.. but it either a) went away or b) i got used to it i dont hear any hissing anymore... |
Originally Posted by minkl81
(Post 10496556)
Feels like i lost some low end torque mayb the ecu is still learning |
straightened the flanges; still same noise...guess i have to live with it...
maybe it is hissing from rapid airflow leaving the exhaust...check out Horsepowerfreaks videos on youtube and see if the sound compares to the M3's... minus 500 hp :(
Originally Posted by 05_NBP_TL
(Post 10505649)
That sucks how we can only make like >350 max HP in our cars huh.. :(
(Post 10497341)
i only get this noise when im on the throttle; but when im off at idle i don't hear it.
Feels like i lost some low end torque mayb the ecu is still learning you obiously reset the ECU ?? i would say it DEFINITELY took my car atleast 100+ miles to get used to the pre-cats do you have your stock exhaust back on with the XLR8 j-pipe? maybe some type of backpressure issues ? |
Originally Posted by BLACKURA_NY
(Post 10507725)
It doesnt really bother me, just kinda odd.. I only have like 75miles on my car since I reset ECU.. Although Ive been driving like a mad man for 75miles.. LOL I wonder how long ECU takes to re-calibrate.. Also how much of a difference could it make? |
it honestly took my car a few days to really adapt to it... and over 100 miles... im pretty sure mine made a slight hissing when they were new... maybe the still do, and im just used to it
you guys are only hearing the hissing with the hood open? or all the time? |
(Post 10507872)
just another Master Of The Obvious question, but is the hiss more like a whistle and happening between 2-3K rpms? If so, that's standard CAI whistle. Maybe it's exentuated with the exhaust mods.
Originally Posted by NedShneebly
(Post 10508038)
no he's not talking about the intake whistle. its totally different hiss. precat deletes hisses like a exhaust leak when gas is given. btw... op, i think what your hearing is the same hiss that i used to have. when precat deletes are pretty new, hiss is more noticeable and starts to tone down as carbon builds up in the pipe. eventually you'll get used to the hiss and will be less noticeable. precat deletes starts to make more torque above 3k rpm, so if you mainly drive in the city, you'll feel less torque compared to stock. this was one of the main reason i switched back to stock cats for more torque below 3k. |
^man, even in the city I get above 3K fast if provoked.
lol :werd:... no but the itty bitty loss in low end torque makes city mpg average lower, and improves the highway
(Post 10510862)
yea but i mainly drive in the city with speed limit of 35mph with bunch of photo radars and cops. 3k rpm isn't much needed to reach 35 unless i just wanna waste gas
(Post 10510961)
yup yup... |
I have the same hiss, but it doesnt really bother me..
Im at 125 miles now.. I wonder when ECU will perform at its potential... |
Thread resurrection!!
Got mine installed 2 weeks ago and same hissing noise upon acceleration. Thought it was exhaust leak and replaced gaskets but noise is still here? Seems like it is common with the PCDs but any solutions found? |
