quick comptech supercharger questions
Car Addict
1 Post
1- they supply smaller battery, from rsx?
2- they supply different battery tray?
3- nothing is relocated?
4- you do not have to change the crank pulley?
5- do you change the injectors?
6- is there a hotwire kit for the fuel pump?
7- is there a handheld tuner used to change the tune, or no tuning is provided?
8- seems like the serpentine belt is changed to now include the blower, ie. the whole setup is on one belt. If that is the case, do you change the tensioner pulley, is one supplied?
thanks!
thanks!
300whp 237wtrq
1- they supply smaller battery, from rsx? Nope, Thats your problem
2- they supply different battery tray? Yes
3- nothing is relocated? Not drastically as far as I know
4- you do not have to change the crank pulley? no change in crank pulley
5- do you change the injectors? Nope
6- is there a hotwire kit for the fuel pump? nope
7- is there a handheld tuner used to change the tune, or no tuning is provided?nope, you get a piggy back which goes to your ECO
8- seems like the serpentine belt is changed to now include the blower, ie. the whole setup is on one belt. If that is the case, do you change the tensioner pulley, is one supplied? It utilzes the stock tensioner but adds a charger tensioner
thanks!
Here are the instructions. This should answer all questoins
http://www.comptechusa.com/store/product427.html
Click on instructions on the bottom
thanks!
BoricuaTL
04-08-2016 01:08 PM
NBP_BALLER
09-23-2015 08:18 PM
acura, acyra, belt, belts, change, cl, comptech, hanged, pulley, rsx, rsxs, serpentine, supercharged, supercharger, tensioner
