Question about the RSB
practicing nihilist
Rear
Sway
Bar
Rear suspension upgrade. Factory for the auto's is something like 17mm and there are 2 companys that make upgrade's that I know of: Comptech and Progress. Comptech's is 22mm and Progress 24mm. It stiffens up the rear end and I noticed more planted with less body roll (swaying), especially in turns.
I installed the Progress because it's thicker and has 2 settings. Search "progress rsb" and also look up "energy suspension bushings". It's a DIY, but read the threads for install carefully before beginning.
Sway
Bar
AZ Community Team
Received 7,771 Likes
Look at this parts drawing, Item #3. That's the Rear Sway Bar.
http://www.acuraautomotiveparts.org/...s=&view=normal
As I understand it, it basically ties the two rear struts together. By holding the struts together the load when turning is "shared" between both sides of the car. By adding a stiffer/bigger RSB, you increase the amount of load the bar can handle.
The result is an increased resistance to twisting and/or equalization of twisting between the two sides. If you reduce body twisting or yaw, you stabilize the car.
At the end of the day on your TL, you'll feel this as a reduction in understeer (pushing) when cornering. The car will have better "balance" and the Rear will "track" better with the front and you can corner a higher speed.
Former Sponsor
Also, it takes the independance out of the rear suspension. Once you go too big you will start lifting the inside tire off the ground. I've seen this happen numerous times in other cars.
With the stock auto suspension, mine is definately bias toward understeer but I had no problems once I got used to it making the rear kick out in corners by lifting throttle on entry.
If it were me, I would add 20% stiffness to the rear springs instead of the sway bar. Mine on good tires will already bottom the rear suspension at the limit which makes it very unpredictable and twitchy. This issue needs to be addressed first IMO. Then use the sway bar to "fine tune" the balance.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
