Question about PCD, race pipe, j-pipe, catback and CAI
2006 Acura TL
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
ok so i have recently installed RV6 PCD, ATLP Jpipe and test pipe and i have a greedy eve 2 cat back and a K&N CAI. so my question is, will it pass smog with just the cat back and cai and j pipe? or should i remove everything except the cat back and intake? or should i just remove everything? this i on my 2006 tl 5at with 117,xxx miles with no problems
To pass visual check: J-pipe catalytic converter is needed.
To pass smog check: Some form of catalytic converter with decent cell count is required. PCD is a no-no as it removes the pre-cats (hence the name). If you change the J-pipe ON TOP of PCDs, your car will be an angry squid on wheels.
Sickboy722 (01-31-2012)
2006 Acura TL
i am also located in cali i know it veries on the state you are in
I'm in California.
Pardon my shitty analogy. What I meant was if you change the J-pipe and delete the pre-cats (PCDs), you will have no catalytic converter. Your car will NOT pass a sniff test, and it will smell like ass.
Either use high-flow pre-cats (HFPCs) instead of PCDs, or keep the stock j-pipe while using PCDs.
2006 Acura TL
lol got confused on your 1st post, but know that u clarified it, i understand. thanks brotha. i might just go back to stock to pass the visual inspection and the sniff test to be on the safe side
Champ, he already has PCD's.
I'm pretty sure you won't have to go COMPLETELY back to stock. as long as you replace the PCD's and the ATLP test pipe with their stock components you'll be fine.
2006 Acura TL
Ok I'll give it a try I'm going to put my stock cats and jpipe and test pipe and leave thr cat back on, has anyone had the gas cap issue? The other day, the display said to tighten the gas cap and I did and stilled keeped telling me to tighten it
BoricuaTL
04-08-2016 01:08 PM
IIDXholic
10-08-2015 07:53 AM
